j
james A Wallace Posted on Oct 08, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon LBP7660 New out-of-box prints with a clouded section missing on the left side of the page. Have reinstalled the software, turned off toner save, and done a soft reset with no change. Any ideas?
ADMIN Andrew
Level 3:
Top Expert:
  • Canon Master 66,967 Answers
  • Posted on Oct 08, 2022
ADMIN Andrew
Canon Master
Level 3:
Top Expert:
Answers
66967
Questions
Helped
5087658
Points
379834
Remove the toner cartridge and tap the end one way, and then tap the other end. After that, tap level to settle the clumped toner. New machine toner cartridges only have about 30% toner content of a purchased one.
Testimonial: "In addition to distributing the toner within each cartridge evenly with no change, I swapped out the toner with 4 working toners from an identical printer and the problem remained unchanged."
I how do I connect my pixmamx922 with my ohone
Apple Airprint:
AirPrint allows users to wirelessly print photos, emails, web pages and other documents without the need to install device drivers, saving time and making for a seamless experience. Both your Apple device and your Canon wireless printer must be connected to the same wireless network connection.
A firmware update for the printer may be needed to support AirPrint. You will need a PC (Mac or Windows), a USB cable and the Firmware utility (available through the Drivers & Software link above) to perform this update.
Google Cloud Print:
Google Cloud Print allows you to print to your Canon wireless printer whether you're in the same room as your printer, or on another continent. You may need to register your Canon wireless printer before using this function.
A firmware update for the printer may be needed to support Google Cloud Print. You will need a PC (Mac or Windows), a USB cable and the Firmware utility (available through the Drivers & Software link above) to perform this update.
Printing from Email
Print from E-mail allows you to print attachment files easily. You only attach a picture or a document from your computer or smartphone and send the e-mail with the attached file.
Aug 07, 2017 • Cell Phones
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
1helpful
Prints lighter on left side of most pages. Even with new toner and fuser and toner darkness turned up to 9 or 10.
This is a bit tricky, but try it
remove the toner cart and lower the top cover about 1/2 way. Look inside and you will see 2 grey rollers hanging from the top on 2 arms. Move the right side arm to the right and grey rollers will fall out (they are as wide as a sheet of paper)
use a light scrubbing with a damp cloth to remove the grey, the rubber should be a tan colour. Dry them off well, insert the left side first (cover in the 1/2 closed position makes moving that right arm easy. install the toner cart again and print a page. It should be nice and dark now, just make sure the rollers are dry when you reinstall them.
2helpful
Low Toner Warning
Turn the unit off. Remove the cartridge and shake it back and forth. Ten place it and turn the unit back on. Also you can reset the counter on the cartridge, go to UNI KIT and look under Brother TN 110 refill support. These people sell refills. The ink you get with he printer is minimal. Also turning the printer off and back on will help with resetting. I found that there is plenty of toner left when the warning comes on.
5answers
Printing
Check the print quality setting on your computer when printing from printing preferences try quality. Also optionally you may want to consider reinstalling the driver,s and uninstalling the printer completely first, as this will restore it to defaul settings.
7helpful
3answers
1720dn dell
Normally to fix a printer that is printing gibberish, uninstalling and reinstalling the print drivers will fix this issue. Another thing that can contribute to gibberish print is using a USB cable that is too long.
With this particular problem (prints Zen), one solve is to uninstall any Dell toner management software. This is particularly true if you are running Vista and hooked up by USB. To uninstall the toner management software (Vista OS), go to control panel>programs>programs and feature>uninstall a program. From this list choose Dell software, choose a customized uninstall, and then choose anything that has to do with Dell toner management.
Missing left edge
Sounds like you should first try the toner cartridge. Make sure you shake it and reseat it in the unit. Print a report. Data Reg., Report
Let me know if problem persists.
2answers
Printing
It sounds like the toner is getting low. Take out the toner cartridge and rock it back and forth a few times to redistribute the toner evenly in the cartridge. If this makes the printouts look better, you should order another cartridge, as this one is getting low. I'm not sure about the L-100, but the toner cartridge for the L-120 fax is good for about 2,000 copies.
2answers
Black Toner Problem
You just might have a faulty black toner cartridge think back did the problem arise when you installed the new black cartridge. Also is the toner a original if not change for a original.
Hope this Helps
Thanks J
1helpful
My laser color 9420
Sometimes when toner starts to get low prints will faed or not print on sides. Make sure the printer is on a very level surface. Remove the toners and shake lightly left to right and reinstall.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
old marine
old marine
ZJ Limited
ZJ Limited
