Computers & Internet Logo
Question about Time Computers & Internet
Latitude E6400 time take to diagnostic boot
There is problem of booting
Posted by alem kassa on
2answers
Dell latitude E6400 Muito Lento. I need help on Muito Notebook E6400-nnnnn.
like this.
this is BIOS asking.
there is no windows running at all, just cold booted
there are web sites that have the cure , for cash paid
google finds them. easy
hit enter 3 times see if you get a PW hint, code
that see means there is back door PW reset, (paid)
Dell Latitude E6410 See and Run F2 setup and F12 Boot menu. See Windows symbol, opens blank screen. Diagnostics: LCD Panel unable to turn lamp on Error code 0326
Okay this is common with that old laptop the problem is usually the lcd inverter i attach a tutorial video for you to see and understand what it is.
this part produces the high voltage required to light up the screen and burn out it is under the actual screen below the plastic bezel which is held to gether by screws under little plastic covers locate at top left right and lower left right of the screen Dell Latitude E6400 LCD Inverter Replacement How To Tutorial
2answers
Main screen with icon comes on then icons go out and a white screen w/currsor and freezes
You should start up your computer from WinPE, a CD residen simplified Windows operating system. It might help you to make some diagnostics. Get it from
http://www.uploadable.ch/file/mKD6atNTMRGF
It's only 121 Mb; burn ISO to CD and boot it . Probably you should change startup sequence on BIOS to boot from CD-ROM
Im trying to reset my dell latitude e6430 to factory settings trying to use keys please help
Try this: Turn on the computer and tap the "F8" key several times to load the "Vista Advanced Boot Options" menu.
Read more : http://www.ehow.com/how_8005941_recover-latitude-e6400.html
I recently got a dell latitude e 6400 laptop windows xp how do I upgrad o change to windows 7 pro service pack 1 32bit
please use win 7 cd and try to change os .
insert a boot cd (win7)
make 1st boot device cd rom
press any key
follow the steps .
My e6400 cant come on. only lights up 2-3s the goes off
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Fn key not working on Dell Latitude E6400
one quick simple test to see if the key works is hold the Fn key and press the power button on a clod boot from power off state. If the PSA diagnostics start the Fn button is functional, and we'll need to troubleshoot other issues.
If the PSA diagnostics do not start, then reseat the keyboard (It has a slot connector into the palmrest) and see if that resolves. If still no change, replace 1st the keyboard, and if that doesn't resolve the palmrest.
http://support.dell.com/support/edocs/systems/late6400/en/sm/html/keyboard.htm#wp1179980
Will not boot to Safe Mode
Try to boot from the Resource CD by selecting the <F12> key and select boot from CD/DVD drive. If you tried to run the "Diagnostics" option from the <F12> boot menu and it went to command prompt, there might be an issue with your hard drive or the "Diagnostics" partition is corrupted or missing. If all tests pass using the Resource CD, then your OS is probably hosed. As for the 9 LED light, that just indicates that your numeric keypad is enabled.
Top Time Computers & Internet Experts
Marvin
Marvin
NOEL
NOEL
Are you a Time Computer and Internet Expert? Answer questions, earn points and help others
