Microwave Ovens Logo
Question about Panasonic Microwave Ovens
Panasonic Convection Microwave Combination Oven . Convection oven works normally but microwave quickly Cuts out . Puzzled don't think its the Door Switches
Posted by roy_stone on
RudolphTerence
Posted on Nov 03, 2022
ADMIN Eric
    Top Expert:
  • Panasonic Master
  • 37,882 Answers
Depends on the model number.
It is either the magnetron, capacitor or invertor.
Posted on Oct 07, 2022
Panasonic microwave convection oven model NN-CD997S works normal but stop heating
Judging from the model and without looking it up I expect that unit has an inverter. If it is not the Switches and you have replaced the mag, the inverter is the power supply for the mag to work so either mag not getting power from inverter or inverter not getting signals from main PCB Timer board.
What is convection cookong
A convection microwave is a combination of a standard microwave oven and a convection oven. It allows food cooked in the convection microwave to be cooked quickly, yet come out browned or crisped as in a convection oven. However, most cakes cannot be baked in a microwave oven - only those without an open grain structure, such as brownies. There are microwaves which contain electric browning baking elements. A true convection microwave has a high velocity forced air fan to circulate the hot air uniformly.
more about Convection microwave
Need user manual for National model no: NN-8655 Microwave oven user manual...
I would suggest that contact the dealer from whom you purchased the oven or call any number listed on the model tag of the oven.
I have a panasonic microwave with convection oven, grill and steamer. When I switch on the microwave, the house fuse (16 amp) cuts out. With the other functions of the oven, it works fine. Do I need a new...
you have a short circuit.
test the a) HV rectifier b) Capacitor HV c) HV transformer d) Magnetron e) test the swich for door for short.f) circuit board main is short.
see the diagrams and proceed.
10_2_2012_12_41_44_pm.jpg10_2_2012_12_42_15_pm.gif10_2_2012_12_42_35_pm.gif10_2_2012_12_43_09_pm.jpg
When started,light& turntable operate normally,but no heating by microwave. Transformer normally sounds smooth,but now makes rattle or vibrating noise,like something is loose.
Check the door safety intertlock micro switch for proper behavior. If it is faulty, the oven will think the door is open and will not turn on the magnatron.
1helpful
Microwave not working but oven and grill do
Test the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Top Panasonic Microwave Ovens Experts
Jaime Hernandez
Paul Bade
Steve
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
