Dyson AM02 Tower Fan Logo
Question about Dyson AM02 Tower Fan
What is the power IC use in Dyson AM02 fan start with LNK---- 7 legs
Posted by LEE KHIN HOOI on
tip
All icons On P.C change to internet explorer Solved
1.go to start menu.
2.run command
3.regedit in run command.
4.HKEY_CURRENT_USER\\software\microsoft\windows\currentvershion\explorer\flexts\
5.search for .lnk ext.
6.delete whole .lnk key or delete the user choice key on that.
7 just restart
on Apr 03, 2015 • Computers & Internet
tip
How to clean your Dyson Cool fan
How to clean your Dyson Cool AM01 or AM06 desk fan, AM02, AM02 Living, AM02 Mini, AM07, AM07 Living or AM07 Mini tower fan, or AM03 or AM08 pedestal fan.
Your machine may differ to the one shown in the video, but the process for cleaning it will remain the same.
IMPORTANT: Please turn off and unplug your Dyson Cool fan before cleaning it. We recommend using a soft, dry cloth or soft dusting brush to clean the intake holes and loop amplifier. Do not use liquids, polishes or detergents to clean your Dyson Cool fan as this could cause damage not covered under guarantee.
on Nov 27, 2014 • Dyson Dryers
No power to Dyson pure cool fan
Check the fans cord. There might be damage to it. Try another outlet it could be the outlet the fan is plugged into. If you see no physical problems with fan. I would enter the serial number in dyson support and see if they will replace the fan. Here is dyson's support page to get started. http://www.dyson.com/support.aspx
Making motor noise
Hi there, it's Jack at Dyson.
It's normal for AM02 to make a certain amount of noise when it's running. But if the motor seems to be making an unusual or loud noise, I'd encourage you to get in touch with us directly so we can walk you through some diagnostic checks over the phone. If a replacement part is needed we can also confirm if your machine is within the 2-year Dyson guarantee.
You can reach our experts directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
tip
Dyson Cool AM07 Air Multiplier tower fan - Getting started
How to assemble and use your new Dyson Cool AM07 Air Multiplier tower fan: adjust the power and oscillation, set the sleep timer and store the remote. The sleep timer can be set between 15 minutes and nine hours.
on Mar 07, 2014 • Dyson Dryers
Dyson AM02 power cord fuse replacement
Inside coil insulation of electric field
110V fan has been plugged in 220V power socket
You may be lucky enough that the capacitor exploded from the 220 volt charge. You will have to enquire at an appliance repair shop for exact advice. Basically I would junk it and get the correct unit for the voltage and cycles in you area.
3helpful
My Panasonic TC-21Z88RBN doesn’t displays the total picture vertically ,when the picture is display it like not in the center of the screen sum of it is disappear in the bottom
Hello
Your TVs vertical output section has the fault. You just open your TV after disconnecting it from the AC mains wall socket, and locate the vertical output section. This section uses an Ic marked as part [IC 401] on the board and its number is LA7840. Just look for any loose soderings around its components legs, and the solderings at the IC legs, which has 7 of them. The IC stated above will be screwed onto a heatsink to radiate heat out of it when it works.
If all soldering point are fine, come towards the IC legs and measure the voltages at each leg. The voltages must be
pin 1= Ground
pin 2= 12.6
pin 3= 24.7
pin 4= 4.4
pin 5= 4.4
pin 6= 24v [vcc]
pin 7= 1.8
All voltages stated above are DC voltages with respect to ground. If any of this voltage is missing, find out the reason for that. If all of them are noted abnormal, IC may be defective, and replace it.
[vcc] stands for main input voltage to the IC.
If you need any more assistance, feel free to contact me through Fixya. Ok.
Open Questions:
See all Dyson AM02 Tower Fan Questions
Top Dyson Dryers Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
NOEL
NOEL
Are you a Dyson Dryer Expert? Answer questions, earn points and help others
