Question about The Office Equipment & Supplies
I have a Eclipse Spyder GS convertible 2007. The convertible will not go down.
My top will not go down. There is no sound to the motor. The buttons will blink orange when I'm driving. An I had to take out one of the fuses to make it stop beeping while I'm driving.
1helpful
My top will not go down on my 2007 Mitsubishi Eclipse Spyder GT Convertible so I had the dealer analyze it and they said the 5th bow sensor needed to be replaced and wanted $450.00 to replace it. Is there...
Definitely want to stay away from the dealer. Might try a respectable garage mechanic and ask him kindly how to go about it. If they know anything about it, I'm sure they can give you advise. You could also purchase a repair manual for the car, this will come in handy when your next problem comes along also. Manuals are around 10-20 bucks and well worth the money.
Keys locked in trunk of 2007 eclipse spyder convertible
at trunk button override and jump switch if dont work have to make way to get through at back seat
Is there a way to get an 07 mitsubishi eclipse spyder GT into gear without the key to the vehicle?
Take off the parking brake and use a wheeled floor jack under the drive wheels to move it for now(don't lift it any higher than necessary).
2007 MItsubishi eclipse spyder Convertible top stuck open
convertible top could be low on hydralic fluid if you have trouble getting top open or closed.check hydralic fluid hydralic pump located in trunk area look for a screw type check plug on side or end of motor pump assembly.give me more detail about back window panel stuck up.
My 2007 Mitsubishi Spyder Convertible top will not open. It appears to be completely closed and locked. Indicator light is on while driving and beeping indicating it is not closed.
it sounds like your motor that opens and closes the top might be going out. with the motor going out it will not send the signal that the top is closed. get the motor for the top checked with a volt meter to see how much power is going to it. if theres a problem with the wiring and its not getting enough power to it, it wouldnt work properly. if it does have enough power goin to it then your motor might be going bad. hope this helps
1helpful
What is the firing order for a 97 eclispe spyder
1997 Mitsubishi Eclipse Spyder GS-T FWD 2.0 liter DOHC Turbo L4
1997 Mitsubishi Eclipse Spyder GS FWD 2.4 liter SOHC L4
Hope help with this (rememmber rated this).
Top only opens half way
You are probably low on fluid.
The pump/motor/reservoir combination is probably behind the rear seat.
Fill it with ATF with the top down. Cycle the top as much as possible, repeat till the reservoir accepts no more fluid in the down position.
Check lines and cylinders for leaks, replace/repair leaks.
02 eclipse convertible top relay??
It is 2 of the same thing. Motor + Relay.
Regards,DT
The passenger side window on my 2007 mitsubishi eclipse spyder wouldn't go down using the controls. Then, when we put the top down, the window went down, but now it won't go back up. I checked the fuse,...
It may very well be the motor. It is the most common problem, as they fail, even though they might work occasionally. You need to try all switches, and realistically see if the switches pass power through to the window motor.
What size after market in dash dvd can I put in 2003 spyder gs
your radio/dash opening DIN size is what they call double DIN, to get the right unit fopr this u will need to know if you have a Facory Infinity premium sound system, it makes a diff in the model f the in dash units, here is a link to a site that has a selection of in dash DVD players for your double DIN dash.
http://www.crutchfield.com/S-nkinM0jziRR/cgi-bin/autoinfo/autoinfo.asp?id=&vehicleid=14718&vb=Y&TypeCH=&lp=%2Fg%5F168550%2FIn%2Ddash%2DDVD%2DReceivers%2Ehtml%3Ftp%3D20217&sl=Y
Top The Office Equipment & Supplies Experts
vince
old marine
old marine
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
