Question about The Audio Players & Recorders
I need a TM-57F-005 E126520 transformer or info on what, please.
I want to know the input and output volts.
Posted by Melquisedec Martinez on
Dale E Weir
  • 3 Answers
You will do better with a wiring or schematic diagram of the apparatus that uses it. Look for input Voltage and output Voltage for a transformer of the same size and design.
You might be able to take it to a refrigeration supply store with cash in hand, and see if they can match it up, or give you the specs for one like it.
Posted on Oct 07, 2022
Simon GATHUKI KURIA
220v and 44v
Roger R
  • The Master
  • 1,642 Answers
Please call Aerotech in order to place an order for the product that you're looking for. This is their number: +1-412-963-7470. Thank you.
I lost my old original power adaptor so I need more specific info for the bms10m.
It is a class 2 transformer. The Conair part number is TEAD-57-121600U Input: 120 volts AC 60 Hz 29 Wats Output: 12 volts DC 1.6. You can try getting an alternative as long as it has the specifications as shown above. I wish you luck.
3answers
1helpful
I need to know the output specs of transformer TM-48F-055E as I blew it up and need to replace regards George.
Hi did you ever got an answer to your question. I think I have the same problem as you had. Thanks
sham
I need to replace the transformer inside my 12 volt charger. I can not find who makes the ES -66-287rev5 transformer. Need help.
If you have the skill to determine the transformer input is open, I would expect you have the skill to replace a transformer. Based on this assumption: determine the input voltage (120 vac?), determine the output voltage (14 vac?), determine the power requirements (output voltage times the charging current), find a transformer at www.digikey.com or www.mouser.com or www.newark.com.
Sep 15, 2014 • Drills
I need either a transformer TM-48F-038m E126520 for a SOST turntable/cdplayer, radio, etc. or information on what the voltage step down is.
Purportedly, this is a generic part once available at Radio Shack. Yes, shockingly, Radio Shack's do still exist. You might see if the part is yet available by contacting them:
https://www.radioshack.com/collections/in-stock-online
I turn my Bose wave system off before bed every night and when i get up in the morning, it is ON...this is a little creepy...can you help?
please my name is dele, my e-mail: [email protected] i have this BOSE radio/cd system model number is AWRC2G which transformer burnt out rightly, that the input is 240volts which output is the problem and in nigria. please i just want to know the output on each coloured wire of the secondary that has 8 wires output from the secondary (2 purple - brn = volt, 2 blue = volts, and 2 black - gray = volts. so that similar that i can use to work it. please i need the reply asap.
thank you
How many parts in transformer & briefly explained
Firstly - DANGER.Power can kill so be very careful.
These can be made of a couple of parts but are sold as one peice.Check your manufacter for more info.
How Magnetic Iron Core Transformers work........
the transformer has a pair laminated wires normally copper or iron core wrapped around in a tight coil called windings.they are independant circuits not electrically connected together(x2 wires = 2 Circuits)
this creates a magnetic effect when power is applied to one end and mutual inductance creates a power output at the other end.Like a magnet really.
There are some transformers that have a multi voltage outputs called TAPS which will have different voltages to the input voltages.
ie
Input in New Zealand can be 230volts
Output can be 12 volts or 5 volts or 230volts
depending on the applications required,
for example
Street Transfomers can be 11,000 volts INPUT stepping down to 230volts.OUTPUT for your household power
or
Garden lighting transformers output can be 12volts but still be 230volts input
or
computers power packs can be multi voltage outputs of 12 volts,9 volts,5volts but still 230volts input.
There are also Electronic Transformers available too.
Commonly used for dichrioc Halogen downlights in homes or the office,
I need the input voltage for ac adapter for my GE 98903 2.1 Pro Speaker System
The AC adapter input voltage is 120 Volts AC as it plugs into a wall outlet. I suspect you want to know the output voltage of the transformer. If you have the old transformer the output voltage is listed on the transformer top. May be hard to read but it is there. This system is also sold under then brand name Jasco. The Input voltage of the system should also be printed next to the power connection or on the speaker itself.
1helpful
2answers
WAVE radio transformer bad ???
If you can check ohms,you can also read volts. Open the radio again and look for DC volts on the rectifiers capacitors.They look like :cans", normally the color is blue. Check for positive dc v. against chassis ground. If no + tension,your rectifier or your secondary are open.
2helpful
Transformer secondary out ???
please my name is dele i have this BOSE radio/cd system model number is AWRC2G which transformer burnt out rightly, that the input is 240volts which output is the problem and in nigria. please i just want to know the output on each coloured wire of the secondary that has 8 wires output from the secondary (2 purple - brn = volt, 2 blue = volts, and 2 black - gray = volts. so that similar that i can use to work it.
thank you
Top The Audio Players & Recorders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
