Question about Sony Audio Players & Recorders
You don’t need special CD-R to record music or data. If you’re having problems with certain brands use Sony CD-R disc. If these disc don’t work, the problem is in the player/recorder. Your Sony recorder should also except CD+RW. These disc are user friendly. You can record over them and edit mistakes. Since the player is older, it won’t play or record on CD+R and CD-RW.
Posted on Oct 07, 2022
Were these discs labeled CD-R Digital Audio? This compact disc recorder can't record to CD-R data disc for computers. See the manual on page 7. The manual is available here: https://www.sony.com/electronics/support/res/manuals/4246/42460761M.pdf .
Apparently, there is a header section on CD-R Digital Audio discs that tells the RCD-W100 that the disc is for audio recording. The work-around would be to process your audio files on a computer and then write the music to the CDs that you currently have.
I wish that I had better news for you.
Posted on Oct 06, 2022
