Question about HP Office Equipment & Supplies
My hp Laserjet P2035 is showing a steady attention light, I have changed the logic Board and the Fuser unit but yet is still on. What can I do. Please
On the laser jet 2035 what does the horseshoe circle symbol mean
If you have the HP LaserJet P2035 (or P2035N), then the LED next to the circle with a small opening at the top indicates the printer ready state. (This symbol/LED is below the triangle with the exclamation mark and above the Go button and light.) If the light is steady, then the printer is ready to use. If the light is blinking, then the printer is processing a job. These apply when no other lights are lit.
If other LEDs are lit, then there is a problem with the printer. See the user guide starting on page 76 for the entire list of LED status patterns. You can find the documentation on the product support page: https://support.hp.com/us-en/product/hp-laserjet-p2035-printer-series/3662025/manuals . The current link to the User Guide is http://h10032.www1.hp.com/ctg/Manual/c01460703 .
I hope this helps.
My hp laserjet p2035d cant print, instead the bin is lighting orange. what could possibly be the problem/cause?
Is the light blinking or steady? The manual is available at the address below. You want to look at pages 78-83, it gives diagrams of the light codes and what they mean. It sounds like your toner is low/empty or missing. Check the manual to make sure I didn't misinterpret what you meant by the bin light.
h20565.www2.hp.com/hpsc/doc/public/display?sp4ts.oid=3662025&docId=emr_na-c01460703&docLocale=en_US
asd
3answers
My printer laserjet p2035 shows fatal error
neither! press the button to create an internal test page. If that works, it eliminates the printer.
What is the cause of a 51.2M error on a HPLJ4600 color printer
Hello
According to HP following is the remedy for this error
  1. Turn the printer off, and turn it on again.
  2. Remove the surge protector or Uninterruptible Power Supply (UPS) and connect the printer directly to a power source.
  3. Try a different power cord.
  4. Try a different electrical circuit or outlet.
  5. Inspect the fuser for media or damage, and reseat the fuser.
    1. Open the top cover.
    2. Locate the green square tab on the right of the fuser flap and lift it to inspect the fuser roller for media or damage.
    3. Unscrew two blue knobs located on each side above the control panel.
    4. Lift the fuser by grasping the fuser housing above the green arrow on the left and right.
    5. Reinstall the fuser.
  6. Perform a cold reset on the printer.
    1. Turn on the printer.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the green c00224695.jpg (Select) button.
    4. Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the check button when the Ready, Data, and Attention light are on steady.
    6. The control panel will display SELECT LANGUAGE .
    7. Press c00224697.jpg (Down Arrow) button once. The control panel will display COLD RESET .
    8. Press c00224695.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
  7. If this message persists, contact an HP-authorized service or support provider. Hope it helps, if so do rate the solution
I just replaced the fuser kit with a brand new NON-refurbished fuser, and it is continually giving me the 50.4 error message and telling me to restart the power and recycle the power. What now?
Hi
Thanks for using FixYa. Error 50.4 means A faulty fuser error has occurred. There may be a problem with the printer's fuser, or inadequate external or internal power supply/line voltage.
a. Open the top cover.
b. Locate the green square tab on the right of the fuser flap and lift it to inspect the fuser roller for media or damage.
c. Unscrew two blue knobs located on each side above the control panel.
d. Lift the fuser by grasping the fuser housing above the green arrow on the left and right.
e. Reinstall the fuser.
a. Turn on the printer.
b. Watch the control panel.
c. When the memory starts counting, press and hold the green (Select) button.
d. Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
e. Release the check button when the Ready, Data, and Attention light are on steady.
f. The control panel will display SELECT LANGUAGE .
g. Press (Down Arrow) button once. The control panel will display COLD RESET .
h. Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
Please see this link for more detailed info--
HP Color LaserJet 4600dn Printer error 50.4 Details
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Attention Light Is Rapidly Blinking Orange
sorry I got it, usually you may try:
1) check all paper road no paper inside include the area betweem input tray and cartridge unit the area wetween cartridge and fuser unit and output tray.
2) check 4 sensor input sensor near the input tray roller, marging sensor between input roller and cartridge unit, cartridge sensor at oneside of cartridge unit body, fuser sensor near fuser roller. usually need to clean or adjustment the position.
3) check input roller and cartridge unit and fuser unit at running condition when the power on.
anyone nothing running show error light blink, also show the hardware trouble if all sensors are normal.
1helpful
Hp laserjet 3380
Not a easy task on one of these, all covers off, doc feeder and scanner have to be disconnected from main pcb and then remove entire assemblys (Entire top of machine ends up sliding back and up/off), then your getting closer to removing fuser..brackets frame off...many screws, if you aint done it, very easy to break.
I broken a few learning but it's the only way to know! There is a Service manual but It is not publicly allowed to distribute it, and to be honest they are harder to understand than the printer... just be logical, patient, gentle, steady, or be smart replace.
Open Questions:
0answers
HP Designjet 1050 / 1055 CM green tint Problem: -------- HP Designjet 1055 CM Postscript: Black and gray-levels printed with green tint Description ----------- My HP Designjet 1055CM PS prints gray levels and black color with green tint. Somehow, the printer does not mix C-M-Y to get the proper color tones. Just to check if using the pure black ink tank as a reference, I tried to force the printer to use it by sending the following simple Postscript test-file to the printer. -------------------------------------------------------------- %!PS-Adobe-3.0 EPSF-3.0 > setpagedevice %%BoundingBox: 0 0 1500 200 newpath 100 70 moveto 0 100 rlineto 100 0 rlineto 0 -100 rlineto -100 0 rlineto closepath gsave /DeviceCMYK setcolorspace 0 0 0 1 setcmykcolor fill stroke showpage --------------------------------------------------------------- It should draw a 100% black rectangle. The test.ps was sent to the printer with the command 'lpr -l test.ps ' The -l should force the cups printing system to send test.ps in raw format i.e. without any preprocessing by the printing system. The processing should be done completely within the PostScript RIP of the printer. However, the print has the exact same green tint as if I print through any application. How can the printer be forced to use the black cartridge? Any idea how to get rid of the green tint? My Mac is running macOS Monterey 12.6 Apart from the green tint issue, the printer is working fine. Any help is greatly appreciated! Best regards!
Ben Johnson
Marvin
Marvin
