Samsung MX-FS9000/ZA Premium Hi-Fi Component Audio System Logo
Question about Samsung MX-FS9000/ZA Premium Hi-Fi Component Audio System
Samsung MX-FS8000E Multi-Voltage Giga Sound Beat Mini Component System. It has a power problem. If I power on after a few minutes will switch off.
ADMIN Andrew
    Top Expert:
  • Samsung Master
  • 53,251 Answers
Question edited for clarity, full 'make model (guessed) (what it is).
Question moved from Samsung Computers.
Power Supply issue, bad capacitors, overheating. Help in the link
https://www.google.com/search?q=Samsung+giga+beat+powers+off
Posted on Nov 29, 2022
1helpful
I have a Samsung Giga sound system MX-HS9000 that keeps shutting off after about minute then after a few minutes I can turn it back on and it does the same thing. Was wondering if anybody else has had this...
Hello Travis, I don't know if your equipment is under warranty (it's an option to repair or replace it) I will add the website to try.
They can be different factors can originate this problem:
Connections: you can check the connections verifying that they are not damaged.
Excess of temperature, a minute or equivalent is a short time, but it is not too much to check; When it is turned off, disconnect it from the power supply and check if it is too hot.
Impedance: check speaker Impedance (in this case you have to use a meter) would be with a mechanic or person with some knowledge of electricity or electronics, but if you have a meter you could also try it yourself: if the measurement does not exceed 4 ohms is deficient and may be the cause of the problem.
Contact Us
How do you reboot a Samsung giga sound system?
no system model stated at all.
this.
Samsung MX-J630 2.0 Channel 230 Watt Wired Audio Giga System (2015 Model)
WHY THERE IS NO POWER WHEN I PLUG IT IN?
Hi I'm having trouble with my 5 disc component system 880 sharp mxp want make a sound like can you please tell me what to do
Trying to get microphone to work for a Samsung giga beat sound
What kind of mic are you using? If it needs Phantom power to work then you're SOL. Invest in a real PA system and you won't regret it. Mackie, Yamaha, Behringer all make good, inexpensive public address systems that will leave your Samsung in the dust.
The system is getting power but no sound is coming out when plugged to any audio device
The good news is that the system is getting power so that section is fine. The not so good news is that the audio section of the circuit board is broken, which can be hundreds of components. So if the system is out of warranty, take a screwdriver and take out the board from the enclosure. Now examine the component side for loose component leads and then on the solder side for loose joints. Next make checks with a multi-meter continuity test between the solder and the copper print for loosened solder. Almost certainly it will be the case of loose solder joint of a transistor/component due to prolonged EXTREME VIBRATION inside the enclosure. Just put your fingers on a working sub woofer to get a sense of the vibration.
So hopefully once certain doubtful solder joints have been identified, just re-solder those points. A few pokes with the soldering iron can do wonders and bring the system back to life.
Also wax up the suspected components so that they don't start swinging again to the beat and get thrown out of the circuit.
I own a sharp mini component system cd- 300w shuts down after volume is on max.
Hi, Possible problem for system shutting down is when the sound IC on the system is getting weak and can't power the system volume up to the max volume range,itshuts down. It's Protecting the system form getting damaged by always shutting down. You will need to replace the Sound IC with another one for i to power up the system to it maximum volume range.
Have a nice day..
1helpful
How to reset a sharp mini component system
Un-plug system.. count to 10.. plug in a switch on again.. usually works,
My Sharp Multi-System Mini component system shelf... is stuck on the ipod setting, if I push audio-in, it goes to audio-in for a second and then switches back, the same thing happens when I try and switch...
Have the same problem. Called Sharp and they told me to do the following:
At front of unit push open/close and stop button at same time. While these are held down press CD button All clear should appear on screen.
Have not tried yet, since I am at work
3answers
No sound whatever
when you switch the unit on make sure that you hear two clicks, this will tell you whether the protection relay is working. Should you hear the two clicks this will indicate that the audio ic`s are working. There are fuses inside the main component box, four on the transformer. Let me know the outcome
craig:)
Top Samsung Furniture Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you a Samsung Furniture Expert? Answer questions, earn points and help others
