Health & Beauty Logo
[email protected] Posted on Oct 06, 2022
My controller is showing fully charged and then all of a sudden dropping to one red flashing light
MobilityRepairSpecialist
Level 1:
Scholar:
New Friend:
  • Contributor 62 Answers
  • Posted on Nov 27, 2022
Contributor
Level 1:
Scholar:
New Friend:
Answers
62
Questions
0
Helped
30911
Points
99
You probably have one bad battery. Replace the batteries if they are near 2 years old and it would probably be a good idea to check the output of the charger.
Why have I got a red light on the bottom of my shaver when I am using it
It is common for many Braun shavers, that if the indicator light flashes red while the shaver is being used (switched on and running), it means the battery is low and needs to be charged soon.
Below is an example from a manual for a Braun model 7526 shaver. You can search that site for other manuals if this is not the correct one.
This model shaver has 3 indicator lights:
1) Green (Charging)
2) Red (Low battery)
3) Blue (Power cord attached and plugged into the wall)
Download the manual for the model 7526 here: http://www.manualslib.com/manual/20281/Braun-5301.html#manual
"The green charging light shows that the
shaver is being charged. When the rechargeable
battery is fully charged, the charging light
flashes or goes off.
If later on, the charging light comes on
again, this indicates that the shaver is
being recharged to maintain its full
capacity.
The red low-charge light flashes when the
battery capacity has dropped below 20%,
provided the shaver is switched on. The
remaining capacity will then be sufficient
for 2 to 3 shaves."
Red light flashing on joystick about 10 min after charging
Most of the time it may be the batteries at fault. One more thing to try is charging the chair with the Joystick on all night 10-14 hours uninterrupted charging. Your chair may suffer from current roll back. There is a circuit in your system that has to be reset by the long charge cycle to reset it. I did not make this up. it occurs when the motors over heat or have a a large current draw. the chair will operate normally for ten maybe even twenty mins. then suddenly drop down to 2 flashing red lights.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
1helpful
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Medion E1210 notebook. Battery has suddenly stopped charging. Didn't get a fall. Laptop works fine when power supply connected, but if plugged out laptop shuts down immediately. When power plugged in...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
1helpful
Pheonix plus batery flat,charged up,now it is mobile but all i have on dial is single red flashing led.
John the red flashing light indicates a low battery When you charge the battery your charger should be showing a red light for power and a yellow light. When the batteries are fully charged you should show a red and green light on the charger. Now if you have a voltmeter plug the leads into the two outter holes of the charger port located under the front of the joystick.Without the charger plugged in you will be reading the battery voltage. Fully charged it should read 27-30 volts if you are only reading 20-24 volts then the batteries are low. If you have an onboard charger plug it in and you should read the charger voltage of 29-32 + volts If you aren't getting that voltage then you have a bad charger if you are getting the charger voltage then you have bad batteries and they need to be replaced Hope this helps you
12v 1.5amp fully auto, alwyas worked, hook up to battery 12v 8.5amph, alwys red light flashed, went solid while charging, then off, or flashed, and off cause was already fully charged. now red light just...
I really don't have any idea as to what you're talking about here other than a battery and maybe a charger. Seems as if you're saying that you have a 12 volt 1.5 amp automatic battery charger connected to a 12 volt, 8.5amph battery but the red light on your charger is blinking. The blinking red light indicates that the charger is not seeing a proper connection such as crossed polarity connection or simply a poor connection. You say that the battery voltage has dropped from 12.5 volts to 9.1 volts with the charger connected. If this is the case, the battery is badly discharged and the charger is not charging the battery for some reason. The charger may be bad but check the connections to make certain they are correct and good. If they are, I'd replace the charger.
Good luck
Steve
4helpful
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
2helpful
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
6helpful
2answers
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
