Washing Machines Logo
Question about Maytag Washing Machines
Maytag washer will stay on continuse cycle even after i reset the computor
Posted by Louis A on
David Spradling
    Top Expert:
  • Maytag Master
  • 13,229 Answers
Bad control board
Posted on Oct 21, 2022
I need reset instructions for bravos mct model mvwx655dw1
How do I reset my Maytag washer to factory settings?
The easiest way to reset a Maytag washer is to disconnect the power to the washing machine for three minutes. Disconnecting the power allows the electrical charge to dissipate from the washing machine, which allows it to reset. If the reset fails, unplug the washer again, this time leaving it unplugged for ten minutes
https://danmarcappliance.com/washer-repair/how-to-reset-a-maytag-washer/
https://www.applianceblog.com/mainforums/threads/maytag-mvwx655dw1-stops-during-wash-rinse-spin-cycle.65341/
I have a new Maytag mvwc565fw. The Clean Washer Cycle was interrupted from a power outage and the unit is full of water and the lid is locked (light solidly illuminated). Trying to start any other cycle...
Resolution:If the washer does not accept inputs from the control panel, follow the Hard Reset steps below to reset the control:
Unplug or turn the circuit breaker off for 30 seconds.
Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
Press the Pause / Cancel / Stop button twice to clear the display.
Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Note: If the Hard Reset does not work, there may be an internal failure with the washer, that requires service.
WHy won't my washer finish its cycle?
check lid switch first, this is most common.(machine thinks lid is open), carefully lift and lower lid an you should here a faint click. otherwise i hit some timer issues but not so common. there is no reset, the model you gave comes back as electro-mechanical and not electronic
Control lock light is on and nothing else will respond, and this continues even after unplugging/replugging. help!
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE /CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
The lock light stays on even when it isn't locked. The washer will not begin a cycle. The only thing that had happened since the last washing was that the washer was unplugged for a little while. Is...
FAV6800A or FAV9800A correct?
If so some troubleshooting is required along with the Service Manual. You can't get the SM from this site.
I would have start some troubleshooting in Service Mode do you want to DIY the fix?
As you saw a power reset will not get you back in service and there is no reset button to reset the Control Board in the Console.
6helpful
2answers
Maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
Washer will not drain on spin cycle, water stays in machine
you might have a broken pump belt go to www.repairclinic.com enter model number and scroll down to the red 100 click it and start looking for the pump part number 1480330. You'll have to lean this thing back far enough to see if it is your belt or maybe even go through the back of it.
Washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
Open Questions:
Top Maytag Washing Machines Experts
Steve
nu267
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
