Question about The Office Equipment & Supplies
I have a vitapur water cooler VWD6956BLS. The piercing valve broke in the bottle collar. I bought a universal part and it didn't fit, Does anyone know where I can get one that fits?
Now I have to pierce the bottle myself and when I try and load the bottle it spills everywhere.
Posted by marilyn nystrom on
john h
    Top Expert:
  • The Master
  • 28,114 Answers
Notify vitiapur your owners manual has info needed or search online allpiance parts ------------https://www.manualslib.com/manual/615671/Vitapur-Water-Dispenser.html#manual
Posted on Oct 06, 2022
Vitapur Water Dispenser. How to replace cold water thermostat on a Vitapur
Question edited for clarity.
Question moved from Cars and Trucks category.
Try adding the model number to this search query
https://www.google.com/search?q=vitapur+replace+cold+water+thermostat
All question need 'make model (what it is)' as the first three words in every question please
I cleaned my water cooler with vinegar but the water still taste bad. What can i do ?
it it is a plumbed in unit running off utility water supply, there is a small ceramic water filter assembly that can be fitted into the water inlet side of the unit
because it is extremely fine it removes the contaminates that make the taste if that doesn't work you can fit in tandem a charcoal filter after that ceramic to guarantee perfectly clean tasteless water
add to the fact that every 12 months ( depending on volume usage) the ceramic filter can be removed and the contaminates scraped off the surface using a knife which regenerates the filter
if it is bottle feed then clean out the holding tank using bleach, wash thoroughly and allow water to run from both taps for a few minutes to remove all residue bleach , the fit new water bottle
spare bottles are subject to algae growth ( taste ) if stored in a well lit area so store spare bottles in a dark room ( closet , under bench etc )
Water cooler runs for 20 sec and then stops says that bottler is empty. not pumping water?
either you faild to unpack it properly and left some thing in the dispenser area where the bottle drops in. It doesn`t pump water, it gavitys out of the bottle.
2answers
Hot water not dispensing
I ve glacier bay hot/ cold water dispenser - new product. Cold water is coming but no hot water. Water is not coming. What have I to do it is a week old machine.
1helpful
I have a obsolete but modern-ish Whirlpool water cooler. The white plastic ring the 5 gallon water bottle sits on is cracked, and chunks are coming off. Whirlpool doesn't stock parts for old model
The collar is only there to keep the bottle at the correct height in relation to the water in the cooler. The principle is that when the vacuum inside the bottle is not being release by the water clearing the opening no more water will run out. To understand what I mean fill up a bottle ( any old bottle) right to the top. Fill up the sink and with you finger over the top of the bottle place the bottle upside down in the water. Take you finger from the hole and it will glug once maybe twice then no more water will run out until you lift the bottle out of the sink water. To stop more running out simply put the neck of the bottle bac in the sink. It is the same with you water cooler bottle. So all you need to do now is to to cover the foam with a piece of vinyle and it will be fixed.
2answers
Vitapur water cooler troubleshooting
Mine was beeping after it overflowed. I could not figure out why, but my husband did. The beeping noise is a warning that your holding tank is too full. Just dispense some of the water and it will shut off.
10helpful
Looking to buy the spill resistant piercing valve part no. HB-CT-1005
My cooler is leaking, and I believe is missing the spill resistant piercing valve. Where can I purchase a valve.
Top The Office Equipment & Supplies Experts
vince
old marine
old marine
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
