Question about The Office Equipment & Supplies
Not error display but cutting is not accurate below 11 inches polar 76 em
Hi machine cutting accurately up to 11 inch but less size cutting is not accurate example when set size 10 inch and also show on display 10 inch but cutting is 10.0625 approx plz tell the solution thanks and regards
Posted by Tariq Hassan on
Roger R
  • The Master
  • 1,727 Answers
you might need to calibrate your machine to make the results more accurate. You can call manufacturer and mention the 0.0625 difference that you're experiencing and see if that fits within what they expect for that machine. Thank you.
Posted on Oct 05, 2022
Blade on Hitachi C12FCH mitre saw has begun to cut into left side of blade slot on turn table. Angle cuts (90,45,etc) still accurate. How do I realign blade run to avoid hitting turntable?
Realign fence to blade, must be 90 degrees, using a level for straight edge bring other fence co planed with aligned fence. . You saw will only cut as accurate as you set it up., I spent over 2 hours on my 12 inch to ensure that it was vertical, exactly 90 degrees and exactly 45 degree both left and right. I used engineer squares.
Are futons sized like regular mattresses?
Futons come in a wide variety of sizes. I found you a great chart that outlines the various sizes of futons compared to mattress sizes.
Mattresses:
Mattress Size
Width
(short side)
Length
(long side)
Twin
36-41
72-76
Full
52-55
72-76
Queen
58-62
78-82
futons:
Twin
39x75 inches
Full
54x75 inches
Queen
60x80 inches
Aug 01, 2012 • Furniture
4helpful
What's the size of a standard Air Hockey table?
There are many types of Air Hockeytables out there. The usual s of an Air Hockey table shifts between 76-84inch long and 44-52 inch wide, the of the surface is 4 inches less thanthe actual of the whole table.
6answers
What are the dimensions of a King Size Bed?
I found this great diagram from United Mattress Warehouse that may be helpful!
May 29, 2012 • Furniture
We are using 8 1/2 x 11 letter size paper. When we print, the top of page is cut off. How do we correct the alignment?
Have you checked the top margin setting of your print job. It should be less than 1/4 inch. If set higher it may cut off the top of the page, before it's sent to the printer. The printer will not print anything within 1/4 inch of the edge of the page, by design.
1helpful
2answers
Can you explain to me about moas? i got this new p4 and im trying to learn how to use it can you tell me? and do i have to site it in at 100 yards first?
If you are going to attempt to sight in your rifle scope for hunting or just shooting, you will need a basic understanding of what a Minute of Angle is.
Think of a circle as it is divided into 360 degrees.
Each degree is divided into 60 minutes.
Each minute is divided into 60 seconds, but we don't use that for ballistics, seconds of angle are just used in machine shops and in rocket science.
Minute of Angle
1 MOA = 1/60th of a degree
1 MOA = 1.047 inches at 100 yards
Most accurate long range scopes are set in quarter clicks (4 clicks = 1 MOA) or eighth clicks (8 clicks = 1 MOA) but less accurate short range scopes are sometimes set in half MOA clicks (2 clicks = 1 MOA)? which to me is the opposite as it should be.
For a .308 the difference between shooting at 100 yards and at 500 yards is about 11 MOA. That adjustment with a scope using eighth clicks is 88 clicks.
Most accuracy testing is done at 100 yards, because it makes the math easier, and it is close enough to see the bullet holes through a spotting scope.
Folks usually say that 1 MOA is equal to 1 inch at 100 yards, which is almost exactly correct, as 1 MOA is only slightly more than 1 inch at 100 yards. But for what we are doing it is close enough. Now think it on out to 300 yards, 1 MOA is then equal to 3 inches. So if your shots are 1 inch off to the left at 100 yards; out at 300 yards, you will be off to the left 4 inches. Clear as mud? Hope this helps.
How to put the paper in the printer?
Loading Paper
1 Adjust the guides to the position for the paper size you are using.
2 Fan the paper well.
Push down the paper lever. Load the paper (with the lever down). Make sure the print side is toward the fax machine and the paper level is stacked below the paper mark. The feeder can hold up to 200 sheets of paper, or up to 10
envelopes.
Acceptable Paper
The FAX/MFC can handle paper that has the following specifications.
But please note that you can receive fax messages only on Letter, Legal and A4 paper. If you use legal or A4, change the Paper Size setting: (Menu/Set, 1, 1.)
Paper Type Paper Size
Cut sheet Letter, A4, Legal, B5, A5, Executive,
Custom size 2.75-8.5 × 5-14 inches (70-216 × 127-356 mm)
Envelopes DL, C5, COM-10, Monarch
Post Card 2.75-8.5 × 5-11 inches (70-216 × 127-279 mm)
Organizer Day-Timer® J, K, L, M 2.75-8.5 × 5-11 inches (70-216 × 127-279 mm)
Labels and Transparencies 2.75-8.5 × 5-14 inches (70-216 × 127-356 mm)
Scale from legal to letter
Legal size is 11x17 inches and you cannot get a legal length document when selected for landscape.
Landscape means that it is 11 inches high and 17 inches wide.
You need to set it to letter and select 11x17 inches.
Printing card
Postcards, 3-by-5 inch (index) cards, and other custom-sized media can be printed from tray 1. The minimum media size is 76 by 127 mm (3 by 5 inches) and the maximum media size is 216 by 356 mm (8.5 by 14 inches). Note You might experience some jams when using any media with a length less than 178 mm (7 inches). This might be caused by paper that has been affected by environmental conditions. For optimum performance, make sure you are storing and handling the paper correctly . Using media from another manufacturer might also help. Printing on odd sizes or weights of media (for example, small, long, or narrow paper) can decrease print speed. The decreased speed helps to prolong the life of internal printer parts. It also improves print quality with these types of media. Guidelines for printing on custom-sized media and cardstock Always insert the short-edge first into tray 1. If you want to print in landscape mode, make this selection through your software. Inserting paper long-edge first might cause a jam. Use the rear output bin to reduce curl. Do not print on media smaller than 76 mm (3 inches) wide or 127 mm (5 inches) long. In your software application, set margins at least 6.4 mm (0.25 inch) away from the edges of the media.
Top The Office Equipment & Supplies Experts
vince
old marine
old marine
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
