Question about Cutter Tools
My Grinding S350 is not booting ever since I tried the reset button while the batteries were inside and an external 6volts was plugged in by mistake. How to fix this problem , please. Thanks.
please replace the batteries first. If that does not work, please attempt to factory reset your device ( can reference manual). Thank you.
Posted on Oct 05, 2022
Testimonial: "I tried these ideas , still it's not working.. Thanks for the suggestions... Appreciate it..."
S350 incorporates with micro computer chip (the component that
controls how the radio operates). If the radio has been subjected to
abnormal environmental conditions, the micro computer chip may
hang up and the following symptoms may appear
The display shows nothing and the radio cannot be turned on by
pressing POWER & SLEEP button.
The display shows random characters or does not work properly
although the radio can receive stations normally.
In these cases, you might need to reset the radio. To reset the
S350, unplug the external adaptor (if one is being used) and
remove the batteries from the battery compartment. Insert a
pointed object, such as straightened paper clip, into the RESET hole
on the right, front side of the radio and gently press and release the
button inside the hole. Then plug in the AC adaptor or reinstall the
batteries
OK.
