Cameras Logo
Question about Green Cameras
Switch on showing DIGITAL CAMERA then blank screen with the green power light
Roger R
  • Green Master
  • 1,639 Answers
Please power down and remove the memory disc from the camera. Then, turn on the camera again and observe the screen. You can double check whether the camera is operating in correct temperatures as recorded in your manual. Overheating or extreme cold could cause your camera to malfunction. Thank you.
Posted on Oct 06, 2022
Testimonial: "Thanks. Looking like the card is the problem. Can the card be formatted in the camera?"
Problem with kodak z650 camera wont stay on
Hello Francine, Sounds like internal fault, need to have service check,may be too costly to repair.
Best Regards, Russell
Screen not working
probably more than the camera is worth LCD screens are expensive
Samsung s730 nothing comes up when turned on
when you press the power button does it show a green light?
try using batteries with 2500mAh/ 1.5 volts or higher
3helpful
Kodak camera shows me a blank/black screen
You have a bad CCD imager. Find a repair shop that can strip a CCD from a camera with a bad lens. This is the least costly repair.
View screen is white (blank) with internal cracks
Look fo the switch that has two setting. one of them will say LCD and the other Migt EVF if you have a view through your view finder this is your problem.
Screen
the screen can be switched off to save power! Make sure screen is set to on position
WEIRDEST PROBLEM
Your battery may be low on power.
Buy new batteries.
Problems with SVP MP-585 Digital Camera
please rate my chat session as per your satisfaction
Jun 23, 2008 • Cameras
Screen goes blank when I plug camera into computer
I have to say Mac's I know nothing about. But the simple way would be to purchase a universal USB card reader- and use that.
Top Green Cameras Experts
NOEL
NOEL
Ngoro
Are you a Green Camera Expert? Answer questions, earn points and help others
