Computers & Internet Logo
LG LCD Television LG43UH6100 error code in PC HRESULT:0x00dc352 cannot use DLNA.
Posted by T P on
ADMIN Andrew
    Top Expert:
  • Computers & ... Master
  • 53,113 Answers
Strugling to download program
Post your OS, Service Pack if applicable. Have you done ALL your Windows Updates? Take a look at this procedure: http://digita7seven.blogspot.com/2012/11/how-to-fix-error-hresult-0xc8000222-net.html
tip
Set up DLNA on Droid X-Share/Stream Droid X Videos/Movies to DLNA Device via...
The <b>DLNA app</b> is what enables your <b><a href="http://www.aunsoft.com/droidx/">Droid X</a></b> to connect to any DLNA devices such as a Playstation 3, XBOX, or a DLNA-capable TV, PC or A/V Receiver, and lets you send a picture or an MP3 from your Droid X to your PC, <b>Set up DLNA on Droid X</b> using the handset as a controller and browse the Videos stored on your PC using your Droid X and then stream it over to your TV using your HDMI cable and the DLNA app. <br /><br />So if you have a Droid X and any DLNA devices such as a Playstation 3, XBOX, or a DLNA-capable TV, PC or A/V Receiver, you may like to stream the movies stored on your Droid X or your Droid X 3gp recordings to the DLNA devices for sharing with friends and family members. And you may have already saved lots of favorite movies in your PC or MacBook, but they are in different formats like TiVo, VOB, AVI, MKV, TS, TP, M2TS, etc which are not compatible with your Droid X and DLNA devices. <br /> <br />Now with Aunsoft Droid X Video Conversion, you can Convert and <b><a href="http://canon-videoconverter.com/2011/06/set-up-dlna-on-droid-x-sharestream-droid-x-videosmovies-to-dlna-device-via-dlna/">Stream Videos/Movies to Droid X MP4 via DLNA for Sharing on DLNA Device</a></b> with high quality . So you need not make great efforts to search for and download or purchase Droid X MP4 movies from websites or online stores. Now the following steps introduce the process of </b>Converting videos to Droid X MP4</b> and <b>Streaming Droid X Movies to DLNA devices</b>. <br /><br />Part I. <b>Convert Movies and Musics to Droid X playable format</b> <br /><br />Step 1. Run Aunsoft Video Converter as the perfect <b><a href="http://www.aunsoft.com/video-converter/">Droid X DLNA Video format</a></b>, and click the "Add" button to load videos with tons of formats. <br /><br />Step 2. Choose Motorola AnDroid MP4 format by clicking the "Format" option and navigating to <b>AnDroid &gt; Motorola Droid (X) H.264 Video (*.mp4)</b> (recommended) or Motorola Droid (X) MPEG-4 Video (*.mp4), which can also play on your DLNA devices. (Tip: The default resolution of output format Droid X MP4 is 480*320, if you don't like it, please click "Settings" to set the size (pixel) you want.) <br /> <br />Step 3. <b>Convert movies/musics to H.264 MP4 or MPEG-4 MP4 for Droid X</b> by clicking the start button under the preview window. After conversion, connect Droid X to PC via USB cable, and <a href="http://www.aunsoft.com/transfer_or_copy_movies_and_musics_to_motorola_droid_x/">Transfer Videos to Droid X through DLNA</a>. <br /><br />Part II. <b>Stream/Share Droid X videos to DLNA service via DLNA</b>. <br /><br />The DLNA service could be used as a stand alone, or used in combination with HDMI. A home network (wired or wireless) or WiFi network shall be set up with your DLNA devices and Droid X. <br /><br />Step 1. Make sure your Wi-Fi network is running. And confirm the Xbox to connect with your Droidx is powered on, and connected to your Wi-Fi network. <br /><br />Step2. On your Droidx, open your Applications tray and select the DLNA application. If you get the message to turn on Wi Fi connection, just click Yes and go to the settings menu to turn on Wi-Fi. <br /><br />Step 3. From the DLNA screen, select "Share media", and select the media (Video, Music, Picture) you want to play in the "My shared media" screen. Then click OK. <br /><br />Step 4. Wait for a few seconds for <b><a href="http://www.aunsoft.com/video-converter/">Connecting Motorola Droid X to DLNA devices</a></b>, and a green DLNA logo will appear at the top of Droid X screen for sharing movies and other media files to any DLNA device like Playstation 3, XBOX, or a DLNA-capable TV, PC or A/V Receiver. <br /><br />With the steps above, you can easily <b><a href="http://www.aunsoft.com/convert_movies_to_droid_x_mp4_for_sharing_on_any_dlna_device/">stream/share Droid X video to PS3/Xbox via DLNA</a></b>. Hope it helps you play around your Motorola Droid X AnDroid phone.
13helpful
2answers
1helpful
DirectSound test results: Failure at step 19 (User verification of software): HRESULT = 0x00000000 (error code)
Run the dell diagnostics on the sound card .
1. Restart your computer
2. tap on the f12 key slowly five times
3. select the option Boot to utility partision or diagnostics
4.select dell 32 bit diagnostics
5. Select customer test and test sound
If the test pass, try system restore , probably the problem is with the sound card drivers
if the sound test fails , shutdown the system again and remove the cmos battery and start the system without it once.Check sound again .
Thanks
proton
It sounds like you may need to Update the Drivers. If not you may have a Bad Sound Card.
Direct sound test results failure at step 19(user verification of software)HRESULT=0x00000000(error code)
That is not an issue...try to use original driver from motherboard website.........
Marvin
Marvin
