Check for loose bolts: Over time, screws or bolts can become loose and cause the magnets to shift, leading to changes in resistance and affecting the bike's efficiency. Consider fastening bolts and screws in their respective places to prevent them from causing such shifting problems .
Inspect the console: If the electric console is malfunctioning, it can lead to error code issues that display on the monitor. Such problems need immediate repair before they cause the entire machine to stop functioning. You can either repair the existing console or replace it with a new one. It's best to leave this project to a specialist who can deal with it effectively .
Contact customer support: If none of these steps work, consider contacting HealthRider customer support for further assistance.
"Does not work" can mean a lot of things, but in any case if you have tried new batteries and checked connections there is generally no economical way to fix it. Check with the manufacturer as to whether a replacement is available.
A stationarybike has basically the parts of a regular bike but it's stationary - it doesn't move. It's apiece of equipment used for exercise rather than transportation.
Simply pull the indicator module straight up out of its plastic holder. No screws are attached. With a thin flat screwdriver pry open the bottom off the module. Insert 2 AAA batteries. Reassemble.
