Video Cameras Logo
Question about Samsung Video Cameras
Samsung VP-D103 flashlight not turning off.
I found a Samsung VP-D103 laying around the house. I plugged it to the power to charge the battery and I can't turn off the flashlight and it's getting hotter. It was laying around the house for a looooooong time so what can I do?
Posted by Steeloh on
Curt mueller
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 161 Answers
Most all devices will heat up while charging the battery. If the switch on the flashlight is defective and won’t turn off the light unplug it from the wall and let the battery die out.
Posted on Oct 06, 2022
Testimonial: "My battery is probably defective because I only have signs of light when I'm connected to the power outlet. The battery is supposedly fully charged but if I unplugged from the outlet it won't do anything so probably I need to get a new battery?"
Roger R
  • Samsung Master
  • 1,804 Answers
Please remove the memory card and hold the power button down for 15 seconds. If that does not turn the light off, please remove all batteries from your device. Please stay away from the power outlet where the camcorder was initially charging. Thank you.
Testimonial: "I only have power if it's connected to the outlet. The battery is fully charged but if I unplug it from the outlet it won't do anything so I think that's the problem."
3helpful
2answers
Re: Battery Charger BC-45W I just purchased a Fuji JZ500 and the battery needed to be charged. When I plugged the charger into the power outlet, the indicator light (yellow) turned on but after a few...
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
1helpful
Fuji battery charger BC-45 - red light blinks when I put in battery and battery does not charge
Battery not charging
You may have a bad battery! (this is the number 1 cause of this problem!) a battery can go bad overnight!
Please rate my response!
Samsung SC-D103 Mini DV
sounds like your tape transport is bad.. something might of broke inside since it almost all plastic.. try to run a dry tape cleaner through..
Battery won't charge/no power to unit
Charger seams defective. get new charger and try.
12helpful
4answers
Where can I download software for my Samsung VP-D103i, to my computer?
where can i down load software for my VP-D103 please, i need to transfer my tape on to PC
Frozen tail cap
Sprayed penetrating oil all the way around the end cap at seal area. Layed flashlight on it's side on a plastic block & tapped on housing just below the end cap with composite mallet while rotating. Then used aluminum jaws in a vise to hold housing while turning end cap with large pliers.
Once cap is off, clean corrosion with automotive battery cleaner & soak inside with more penetrating oil to remove batteries.
Tonka Roy at Rosell Infiniti
Samsung VP W95D Hi 8 Camcorder
are you trying to charge the battery while on the camcorder??? does the camcorder work when you plug the camcorder into the charger?? If the battery fails to charge while its on the charger it can only be the charger but most likly the battery. If the camcorders dead it could be the dreaded pana cap think thT HAPPENS TO MOST CAMCORDERS AFTER A LITTLE AGE. good luck
LCD problem...
Most of our camcorders have an option to turn the LCD brightness up or down but not to turn the LCD off. If the brightness is turned up and the LCD will not turn on, the battery may be very low, or the unit may require service. The following Articles provide model specific instructions for making LCD adjustments. The majority of Samsung archived camcorders use the same instructions as the article for the SC-D103/SC-D107.
Top Samsung Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
