Question about Pioneer Audio Players & Recorders
No optical light from pioneer vsx516
No sound from receiver and speakers 7.1
Posted by Ronald Dean on
Roger R
  • Pioneer Master
  • 1,698 Answers
Please double check that you've adjust the volume on the speaker and test sound with multiple sources (ie CDs, DVDs etc) to ensure that the volume/sound issue is cause by the speaker and not the item that it's attempting to play.
You can also check for any disconnected wires going from or to the speaker. Thank you.
Posted on Oct 06, 2022
Pioneer vsx-515 trying to connect to sony bravia lcd tv and wharfedales speakers with 12'cube sub... any wireing diagrames please? I do have an optical wire to has have been told they...
Optical is the clearest information you can get.
Its pure light!!!!
Sony bravia has a optical out, plug that into optical in on your Receiver.
reciever should have a dedicated sub woofer lead out.
obviously goes to the subwoofer
then just your speakers, i'm assuming you know to match wire colour of speakers to colour of the rear of your reciever. that is red to red, black to black??
If by chance your wires are not red and black, red is positive on your receiver, black is negative.
The receiver outputs for speakers will be written so you know which two outputs(red and black) go to which speaker.
Make sure you match positve to positive and negative to negative, otherwise your speakers will
sound real dull and you won't know why.
Hope that helps.
1helpful
Not getting sound thru speakers only tv with hdmi cable connected do I need to connect Digital fiber optic cable too Also able to download owners manual for vsx1017txv
Receivers of this complexity require some patience. I believe the HDMI on this receiver is only for on screen display and video pass through. The audio needs to be separately connected. For digital audio you need to connect either via the digital audio coax or fiber optic input. I replaced my entire 1980s audio system with this unit and have been very happy. It's compact, and I feed it everything via a 35' fiber optic cable (under $20!) tied to a 3-way passive fiber switch (under $10) connected to my computer, a Tivo, and a DVD player. Sounds amazing (make sure to run set up to get the unit to perform with all of your speakers! -- I use an 8 speaker 7.1 surround set up).
Pioneer VSX-72TXV used to work but trying HDMI just broke it...
I fixed it myself. Didn't realize that I loosened speaker cables on the wall panel when I moved the receiver and two were touching...
2helpful
Pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
1helpful
No surround sound like the movies
HOOK IT UP FROM A DVD PLAYER OR BLU RAY,,, WITH EITHER COMPONENT OR A OPTICAL CABLE ,,MAKE SURE YOU HAVE ALL OF IT TURNED ON ON THE RECIER SETUP
No sound from speakers after connecting to pioneer a/v vsx81
I had the same problem and resolved it last night. You'll also need to connect an audio cable (EVENTHOUGH YOU SHOULDN'T HAVE TO - to bad pioneer didn't fully implement the HDMI standard in this receiver) solution. I suggest using an Optical cable. This really annoyed me...see the manual on P.17 section #3.
HELP Blu-Ray to Pioneer DVD Suround System connection
The receiver that came with your speakers should have a digital input for a dolby digital source. On the back of the receiver it's probably labled "digital coax" or it could be an optical as well.
Your new Blu-Ray has these outputs on the back. it's as simple as getting the correct cable and selecting that input on the receiver.
To make sure you get the right cable, look at the back of the receiver, and the blu-ray. Look for the digital input on the receiver, and get a cable that matches that. It's either a single RCA cable, or an optical.
So when done, you will have the HDMI or Component out from the Blu-Ray going to the TV, and the digital audio going to the receiver. To hear the sound through the receiver, just go to that input on the receiver.
TV/SAT Video channel went out - Pioneer VSX516
Double check the video connection cable directly out of the SAT reciver and the video cable out from the Pioneer reciver, as there maybe an intermittant connection in them. If you replace them or sub them for known good ones, and you still have this probem, there is a switching IC inside the pioneer that has to be replaced.
Open Questions:
Top Pioneer Audio Players & Recorders Experts
David Shaub
Steve
Morne Olivier
Morne Olivier
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
