Televison & Video Logo
Question about Runco Televison & Video
What does the trouble code 19 on my runco cinema wall mean
When I turn on my runco cinema wall television it just displays a giant number 19 in green what does that mean
Roger R
  • Runco Master
  • 1,698 Answers
The error is not appearing on my end. Please check the troubleshooting section of your manual for the error 19. And if necessary, you can call Runco directly to help overcome the error. This is their phone number: 1-888-785-2677. Thank you.
Posted on Oct 06, 2022
Runco flat panel tv displays solid green then blinking red light. What doe this mean?
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Green tint
Sounds alike a panel fault. Check this link for more details. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
1helpful
On a runco cw50mc where does the satellite cable hook up on the back?
It doesn't. This is a "monitor". The best input for sat or cable TV is via the component (red, green blue) input or possible the DVI.
We have a Mitsubishi Big screen projection tv model no. VS-50705. when the on button is pushed it clicks like it wants to turn on but then doesnt. When I unplug and plug back in the green light flashes...
This could be a trouble code for your model television. Try counting the blinks and note any pauses in blinking. It could be a one or two digit trouble code. Then once you have that number, type in your tv model along with the words "trouble codes" or "diagnostics codes" or "green light blinking" and see what you get. Hope this helps...
2answers
PlasmaWall PL-61cx Runco; what's a 7 year old broken Runco worth seems to be a power supply problem?
Do you still have the tv? What happens when you try to turn on the tv, does it even turn on?
Top Runco Televison & Video Experts
Marvin
Marvin
Tom Chichester
Are you a Runco Televison and Video Expert? Answer questions, earn points and help others
