Televison & Video Logo
Question about Vizio Televison & Video
I have a Vizio M50-c1 and have no picture
My tv has no picture but has audio and I have pulled the one cable off of the T-Con board on one side and I get half a picture and when I do the reverse on the other side no picture what could my problem be can you help
Posted by Melvin Epps on
Larry
  • Vizio Master
  • 4,632 Answers
You have a bad panel, time for a new TV
Posted on Oct 04, 2022
Vizio M50-C1 two images on screen My TV show one image split into two.
Are you saying that the same picture is split into two, or that there are 2 images split on the screen? Might be the PIP board or setting on the remote that is bad.
I have a Vizio LED TV, model M50-c1. I have audio but no picture. No backlight. First step to replace t-conn or main board?
Chances are your T-con may be bad . I would check the backlight by shining a flashlight by the screen to look for an image on the screen . If an image is present, then the backlight is the problem. Your Tcon and main board could be ruled out, if this is the case . At this point check the power board for voltage to the led driver. The leds could have issues.
I have an M50-C1 model Visio LCD tv and being told I need to replace my T-Con board. Do I?
The T-con board is inexpensive. Try replacing it. You will find one online for cheap price with a google search.
I have a vizio tv model m50-c1. I have audio and backlight but nothing on screen. I have replaced the t conn board and did not fix the problem. Any idea on what my next step would be? thanks
1. Screen buffer test: Disconnect the two flex cable between the T-CON board & the screen one by one to see if one cable is disconnect the picture is come on a half a screen or not, if it does, the screen buffer board is bad that is not fixable, you need a new screen.
2. If the buffer test with no result, i will try a new main board.
1helpful
TV image vibration
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
MY VIZIO M50-C1 TV BROKE, AND I NEED A LITTLE HELP. I REPLACED THE POWER BOARD ON IT AND THE SAME THING STILL HAPPENS.
If you have no picture and no sound, go with the main board first since that board works with both. If you have sound try the t con board first since it specializes in the video that appears on our screen..
Open Questions:
Top Vizio Televison & Video Experts
Marvin
Marvin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
