SIEMENS SIWAMAT 6102 - A few minutes into a washing programme the spin light is flashing, beeping begins and the cycle stops. What can be the problem please?
My first thought was that it was a problem with the drive belt or tensioner, but if it spins, that can't be the answer. That points to a main board or motor controller problem. In the first instance try a Power Reset. Disconnect the machine from mains power for a couple of hours, or preferably overnight. Press and hold the power button for 30 seconds and then plug it back in. If that doesn't fix it, you need a service call. It doesn't appear to be a known issue.
when the machine is stopped can you empty the residue water that remains by the programme selector? if not check for blockage in the pump(coin), the hose internal blockage ,or at the outlet under sink. I hope this help
Yes - mine has just frozen in the garage and cracked whilst defrosting. Water everywhere. Does anyone know if I can bypass it and run the M/C on cold only?
hi, The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
The pump was working but not pumping. The rubber hose from the bottom of the drum to the pump was removed and found to be partially blocked. The debris inside the rubber hose was cleaned out and reassembled with no further problems.
