Computers & Internet Logo
Nautilus T9.14 Buttons don't function regularly
All of a sulden the buttons to set a program don't work. For example, sometimes I can select interval and add my weight and work speed, but then the buttons don't work any more. After disconnecting I can only select the interval training and then nothing works... And even sometimes nothing works after reconnecting. If I do nothing and wait I hear an accessional beep, and sometimes it beeps twice after entering something instead of once. After it beeps twice nothing works any more... I can't reset to default, because not all the buttons react. The strange thing is sometimes It allows a few settings and sometimes none. I am from the netherlands, can't find a local service center. I do own a manual, but can't find an answer
Posted by Mischa Kienhuis on
Ingot my Philips remote programmed on my tv and DVD player. It works but when using DVD player the buttons don't function as its proper function. For example the play button puts the tv on mute,
It is a common problem with any universal remote controls. Try an other code for your device. Select one code which has maximum functionality. Than is the only thing have to do.
Some of the buttons (Start, Select and sometimes Home), don't work. What's the problem?? And sometimes, in game, home keeps showing!
the buttons are stuck take it apart and clean them and if that does not work buy replacement buttons from ebay or amazon
3helpful
When I push the SCAN button I get a message that asks me to 'specify the program where the scanned image is transferred'
You need to set up the destinations in the Canon software. First launch the Canon Scan-Gear Toolbox. The Scan button on the scanner is the same as Scan-1 button by default but no software is linked to this button. Click on the Scan-1 button then choose Set. Then set your application that you will want to work on the scanned image. Select your application (Photoshop Elements, for example) - the exe file if using Windows. (You may need to browse the Program Files folder and then the individual application folder (C:\Program Files in recent versions).) Then click Open and then Apply to confirm this. You can also select the file type that you want the scans to be saved as in this settings window.
If you want to change the scan destinations, then click on Settings (on the far right). You will see the drop-down menus for each of the scanner buttons. Select the desired function for the scan button and click OK. (Scan-1, Scan-2 and Scan-3 can be linked to other software.)
I hope this helps.
This page is not opening
The internet requires getting familiar to achieve navigations experience. First, the computer has a help button that provides references for user misunstood function tasks. For example, when confused about how the computer programs functions, simply find the help buttons for explanation diagnostics procedures. The computer has two help functions one located on the F1 key for performing technical repairs to the entire device. The second help functions of the computer provides program explanations located on the start bar task list functions area. Clicking on the help and support functions should provide the means to user ambiguity resolution diagnostics installed by computer manufacturer. However also, each computer program once opened would have a help button on the top function buttons usually for resolving only issues related with ambiguity on the program being displayed only. Finally, the internet pages or sites have help diagnostic buttons from which user ambiguity is acquirable. Once opening an internet page, among the list of displayed button has one as help support functionality providing details usually of capacity expectations. Most computer linked to networks require rubric of internetworking to be attained requiring familiarization. For example, local area networks may require search processes dissimilar with comparison to World Wide Web search functionalities of www.worldwideweb.com for example as rubric to provide display results of any available.
I lost my sound on my Samsung LN-T4061F tv. it was plugged into my stero.. was fine.. and now no sound. Not even on the regular tv. HOw do I get the sound to work at least on the regular tv?
hi,
i think ur tv's internal mute function is ON. change it to OFF through the following setup.
1. Press the MENU button to display the menu.
Press the ? or ? buttons to select "Sound", then press the ENTER button.
2. Press the ? or ? buttons to select "Internal Mute", then press the ENTER button.
3. Press the ? or ? buttons to select "OFF", then press the ENTER button.
Press the EXIT button to exit.
ok
1helpful
I also am having trouble with this timer. I've got the program set for when I want it to go on but can't figure out how to put in the time I want it to stop. I don't understand where the countdown timer...
ETW350 is programmable timer that offers 3 different timer
functions: Program, countdown and random.
Timer has 20 different settings.
UPM site is not available recently, but UPM timers are still being sold.
Operation manual is not very clear how to program ON and OFF times.
http://waterheatertimer.org/pdf/UPM-etw350.pdf
That being said, usually with programmable timers, you program ON time. And then program OFF time.
I do not own this timer so I can't test ETW350 like I've tested other timers.
I think the way this timer works, is program1 is ON.
And program2 is OFF.
Again, manual is not CLEAR about ON and OFF times.
Following instructions assume timer is wired correctly, timer is set for current time, and you want to set 'timer' function and not 'random' function.
Here's how to set program1.
Press arrow buttons until 1 shows in display. This is program1.
Press Set button.
Select day for program1 ON using arrow keys
Press Set button.
Select hour for program1 ON using arrow keys.
Press Set button.
Select minute for program1 ON using arrow keys.
Press Set button.
Use arrow keys until 2 appears on display. This is program2.
I believe program2 is for OFF times.
Set program2 using same steps above.
Be careful to match ON and OFF days ... for example ON 7pm Monday and OFF 9pm Friday will keep lights on from Mon through FRI.
Conflicts in programming will cause timer not to work. For example program1 ON 7pm Monday, program2 OFF 9pm Monday ... but programs3-4 say opposite times.
Make a schedule of program times before starting to avoid conflicts.
Try steps above and test fire that timer, and then add a comment.
2helpful
How to tell what the buttons do?
The HOLD key lets you freeze the scanner on an active channel. For instance, if the scanner stops on channel 3, and there's a lot of action there. you can press HOLD to lock the scanner on that channel until you press the SCAN key. Repeatedly pressing the HOLD key will manually advance the selected channel.
SCAN releases a HOLD asnd will also take the unit out of PROGRAM or SEARCH modes and start it scanning the frequencies that you've programmed.
FUNCTION selects the secondary (lower) function of a key. For example, pressing FUNCTION and then the E (ENTER) key will switch the scanner to Pgm (Programming) mode - which lets you enter and store frequencies into the unit's memory so that you can scan them later.
All keyboard functions are explained in detail in the scanner operating manual, which you can download/print here:
http://www.uniden.com/pdf/BC92XLTom.pdf
For a comprehensive database of active frequencies in your area, along with a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
9helpful
3answers
Is there a way to switch to Video without the remote on my Spongebob Squarepants Emerson 13 inch TV"
Unfortunately it looks like there is not a way.. go to radio shack and get the RCA 4 device remote model #RCR4383N $10.00. use the directions to program it automatically. just did my son's tonight, works like a charm. use the input button at the bottom to switch to and from AV input.
I can't really see it but is there a menu button on the front?maybe go threw the settings add channel and add video to the channels.
No instructions need to know how to operate
The Nikon MC-EU1 Remote Cord is an accessory available for the Nikon COOLPIX 880/885/990/995 4300/4500/5000/5400/5700/8700 cameras. The MC-EU1 Remote Cord is 80 cm long and allows the camera to be fired remotely like a cable release for a film-based camera.
The MC-EU1 Remote Cord's main function is to prevent camera shake. As well as the shutter release function, the MC-EU1 has the following functions.
1. operate the camera's zoom remotely,
2. advance or return images in the playback mode,
3. Controlling interval photography, automatically fire the cameras over a given interval.
Note this is the only Nikon remote cord available NIKON COOLPIX cameras and is only compatible with the cameras listed.
The Nikon MC-EU1 remote cord has two Interval modes, A and B
In Interval Mode A: the first photograph is taken at the start; and subsequent photographs taken at the specified time intervals, thereafter.
In Interval Mode B: the first photograph is not taken until the specified time interval has passed and subsequent photographs taken at the specified time intervals.
These modes can be selected by pressing the MODE button. The device cycles through settings in the order, Remote Mode, Interval Mode A, and Interval Mode B. When the Remote Mode is selected, the LCD panel displays Remote; when Interval Mode A is selected, Interval appears together with the letter A and Interval Mode B is indicated by Interval and the letter B.
The interval Modes, allow you to take photographs one after the other at a selected interval, which can be set in increments of one second to any value from two minutes to twenty-four hours. Interval modes are only available when the camera is in recording mode and cannot be used when the camera is in playback mode.
Setting the Interval
1. Setting the camera to recording mode and the remote cord to Interval Mode A or B, the interval setting will be shown in the remote cord LCD display. Items currently selected for editing will flash. Each time the selection (SEL.) button is pressed, the item selected will change as shown below.
Select the desired time by altering the settings (second [S], minute [M], or hour [H]) one at a time. While the item is flashing, press the down button to decrease the time set, or the up button to increase the time set. The value displayed will change by one each time either button is pressed.
2. After adjusting settings, press the selection button until the display is no longer flashing.
Starting Interval Mode Photography
• Half-pressing the remote shutter-release button has the same effect as half-pressing the shutter-release button on the camera, readying the camera to take a photograph. If the interval is set to less than two minutes when the shutter-release button is half-pressed, the interval display will flash. Choose an interval of two minutes or more.
• Full-pressing the remote shutter-release button has the same effect as full-pressing the shutter-release button on the camera, starting interval mode photography.
• When the camera enters interval mode, it will either take a picture and then begin the count to the next photograph (Interval Mode A), or begin the count to the first photograph (Interval Mode B). The Interval indicator in the LCD display will flash while interval mode is in effect.
Ending Interval Mode Photography
• Half-pressing the remote cord shutter-release button while an interval mode is in progress stops the interval photography.
• Photography will also stop should you run out of available space on the compact flash card; In this case, the number of exposures remaining displayed in the LCD panel will be 000.
The MC-EU1 has a feature that when the zoom button is pressed twice in rapid succesion, the camera will start zooming until this function is cancelled by pushing the button a third time. If this function is not cancelled, no other function is possible with the MC-EU1. If the MC-EU1 does not respond as expected please ensure you have not activated the zoom function.
Marvin
Marvin
