Computers & Internet Logo
Question about The Computers & Internet
Toyota Camry 1998 model. 5s ,My OD button flicks n engine check lights gets on .when engine and Od lights gets off ,it doesn't changing the gear
WHAT CAN I DO TO SOLVE IT MATE ??
Posted by Supreme Trap24z on
Roger R
  • The Master
  • 1,639 Answers
if the check engine lights comes on, then you need to have your car scanned to get a list of full error codes checked . And then with the error codes, the technician can tell you what's wrong with your car. A place like autozone should be able to to this for you for free, but I would advise calling ahead. Thank you.
Posted on Oct 04, 2022
Transmission not shiftin
For car not changing gears it can be shifter assembly issue, or it can also be transmission issue. Get the shifter assembly inspected with ignition OFF.
For more troubleshooting, I suggest you to get the Following help link checked, its complete step by step procedure to inspect gear shift issues: -----
GEAR SHIFT ISSUES
http://alltypesofpartsreplacing.blogspot.com/2012/11/gear-shift-issues.html
TRANSMISSION GEARS SLIPPING AND FLUID LEAKING ISSUES
Transmission gear assembly and transmission needs inspection. Also check the transmission fluid level. Also is the fluid getting leaked or its low.
There are few very helpful links with solutions to troubleshoot this problem.
I suggest you to refer these links.
Click the link below:-----
2000 Toyota Camry: Transmission slipping and Stuck up?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
Car engine Overheats and transmission starts slipping?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
2006 Ford Explorer: Engine Vibrates and gears slipping?
http://whatisbyme.blogspot.in/2012/06/2006ford-explorer-engine-vibrates-and.html
Clutch slipping problem?
http://howtobyme.blogspot.in/2012/03/clutch-slipping-problem.html
Dodge Anti slip System is not operating?
http://whatisbyme.blogspot.in/2012/07/dodge-anti-slip-system-is-not-operating.html
OD light flashing and transmission fluid leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Transmission fluid leaks near radiator on ford windstar?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Ford Windstar transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
These details will help.
Thanks.
Replaced 2 3 sol in trans goes forward in all gears
TRANSMISSION REPLACING AND TROUBLESHOOTING
http://alltypesofpartsreplacing.blogspot.com/2012/12/transmission-replacing-and.html
Thanks.
1986 olds 88 trans slipping
Transmission gear assembly and transmission needs inspection.Also check the transmission fluid level.Also is the fluid getting leaked or its low.
There are few very helpful links with solutions to troubleshoot these problem.
2000 Toyota Camry: Transmission slipping and Stuck up? http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
Transmission Slips out of 2nd gear? http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
Car engine Overheats and transmission starts slipping? http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
2006 Ford Explorer: Engine Vibrates and gears slipping? http://whatisbyme.blogspot.in/2012/06/2006ford-explorer-engine-vibrates-and.html
Clutch slipping problem? http://howtobyme.blogspot.in/2012/03/clutch-slipping-problem.html
Dodge Anti slip System is not operating? http://whatisbyme.blogspot.in/2012/07/dodge-anti-slip-system-is-not-operating.html
Ford Windstar transmission fluid leaking? http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
Thanks.
Trans starting slipping after modulator replaced
Thanks.
1helpful
What will cause the engine light and the OD lights to flash when engine is running? this is on a 95 toyota camry 4cyl.
Transmission problem or electrical issues
You will need a shop that still has older
OBD1 System scan tools & knowledge
(OBD1 1983 thru 1995) Newer systems are obd2
2answers
"OD off" light up on
The OD is a extra gear do you need it not really you can drive 150 miles if anything its the switch button that went out
Light indicating 'o/d off' just came on. No other problems.thanks jim L
Hello, welcome to FIxYa.
The OD Off light has been activated by someone moving the small square button on the side of the shifter. This button allows the OD to engage, or is prevented (OD Off). To rectify this, depress the button on the side of the shifter.
I hope that my assistance proves beneficial to you.
Thanks for choosing FixYa.
1helpful
My son press some of the buttons and it displays "O/D OFF". please tell me how to turn on O/D. Early response would highly appreciated. REgards Jacob Francis
Hello, welcome to FixYa. Please allow us to assist you.
The OD OFF light has been turned on via the small square button on the side of the shifter handle. This button should normally be in the 'depressed' position, which allows the OD to engage. The OD OFF light is illuminated on the inst panel to alert you that the OD has been manually disengeged. The OD is the final shift of the transmission, thusly giving you maximum fuel mileage.
To rectify this, press the button on the side fo the shifter handle.
Thanks for choosing FixYa for assistance today.
2answers
What is the O/D for?
no you dont need it on its the over drive
Top The Computers & Internet Experts
vince
NADARK
NADARK
A Kisling
A Kisling
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
