Televison & Video Logo
Question about Samsung Televison & Video
Samsung dv70 combo DVD and VHS
Machine was working but not perfect then no functions with disc and VHS stuck in the machine only sign of life when powered up gentle throbbing noise and video head rhythmicly moving with judder no response to remote or fascia controls . is this the end of the machine . power supply or other fault . was only using the unit to recommision an old b& O tv lx2800 but could not get a FTA channel going thru a stb . thoughts thanks as the recycle bin is close by
Posted by david beetson on
Can i record data from vcr to dvd
If you want to convert VCR tapes (VHS etc) to DVD discs then your best bet is to buy a second hand combo VCR DVD unit that will make life easier for you.
http://www.ebay.com/itm/dm-40-Samsung-DVD-VR357-VHS-VCR-DVD-Recorder-Combo-w-HDMI-/121234178922?pt=DVD_Players_Recorders&hash=item1c3a1ec36a
Otherwise you can buy adapters that need to be converted to PCs and this can be messy.
This article gives some idea about using PC capture units with software.
http://www.ebay.com/gds/How-to-Transfer-VHS-to-DVD-/10000000177628047/g.html
Why is the VHS eject button stuck on my samsung v1000?
Button stuck - not cassette stuck in the player? If there is a cassette stuck, the machine has to be opened to get the tape out.
3answers
I have a Panasonic DMR-ES30V. I've only ever recorded from what I'm watching on the TV to a DVD. I now have a VHS tape that I'd like to record to DVD. I tried starting the dvd to record...
Most Combo Recorders (VHS and DVD) will prevent you from
recording a Copyrighted VHS tape program onto DVD.
Try recording a TV program onto your VHS tape, then
transfer it to your DVD and see if your new DVD recording
will work or not.
1helpful
I hyave a samsung 5500 DVD & VHS Combo DVD doen't work. IT says Disc is not working , Please check disc
you can try and blow some air into the DVD as the lens of the laser may be dusty. otherwise you may have a bad laser. They used to sell a "cleaner" disc for this reason. Check your local video stor or a big retailer.
2answers
I want to put my VHS movies onto DVD's.
It will copy VHS to DVD. Provided that it is a home movie and not a copywritten movie from the store.
2answers
HOW DO I RECORD A DVD TO A VHS ON A VHS DVD COMBO BY PHILIPS
Cannot do this on a combo unit. There is a chip that senses copy protection and prevents recording a copy-protected DVD to a VHS and vice-versa. Solution: Use an outboard DVD player or an outboard VHS VCR and try the recording with the video routed through a "stabilizer" box. The stabilizer (about $30 or less on Ebay) defeats the copy protection on MOST DVDs, but not all. It works with Netflix DVDs. Route the audio as usual. Audio is not protected.
Can't copy to DVD
Most movies , on VHS , need a small decryption device to get rid of the ( Macrovision) protection, which will not let you record from VHS to DVD. I have one here that I use , works perfectly. It also decrypts from DVD to DVD , in case you need to back up a movie. Kids are allways banging DVD with scratches and it's not to copy the original & give them the copy to mess with, that way you allways have a perfect one in stock. If you ever need a converter , I have one left but works great. emailme:[email protected] if interested?
Copying disc of videocanea
With a combo machine you are usually stuck making another disk from your VHS tape-unless yours has a hard drive. Or you could make a copy with your computer DVD recorder-much faster by the way.
I don't know about adding music and naration it all depends on what your manual says your machine can do.
Problem reading DVD-R
Need more info.  Do other DVD's play on the Samsung?  Some players play DVD-R and some don't.
1helpful
2answers
Sanyo DMW-3800 system problem
call jinnie at sanyo
ph # is 870-633-5030
for the 9 pin cord from unit to subwoofer
Marvin
Marvin
