Televison & Video Logo
Question about Sharp Televison & Video
Sharp 14V-R70M Default Service Mode
My Sharp 14V-R70M TV won't turn on after it returns all defaults in service mode. How can i fix it?
Roger R
  • Sharp Master
  • 1,804 Answers
First, please check that your one of your tv remote buttons isn't stuck because this could cause your tv to continuously go into a certain mode.
You might then attempt to factory reset your tv to stop the service-mode issue. Please reference your device's manual to help with this. Thank you.
Posted on Oct 04, 2022
1helpful
My tv, sharp, does not power on. it only shows the word SHARP for a few seconds and turns off. what may be the problem?
Do a hard reset to this set, and then check. If it do not help, check and replace its main digital board.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
SHARP LCD TV DEFAULT SETTING
To make it a factory reset, you have to enter its service mode option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
I have the Sony 50R550A L.E.D Television and for some unknown reason the tv keeps returning retail/Demo Mode
Do a reset to this TV and check. If it do not help you, contact any service technician. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
How do I get to ch 3 on my sharp 13f-m50?
Try this:
while holding vol- & input buttons on tv plug in set when "k" appears push vol- & chan-
You will have to look around the menu for the reset option to default to ch 3. Be careful. You are in the service mode.
1helpful
2answers
No sound
Press the mute button on the remote control. If it do not help you, you have to enter its service mode to unlock sound. For more details can be get by http://electronicshelponline.blogspot.com/. The linked site has details about how to enter service mode, and make adjustments, to many brand televisions, including several model Sharp TVs. Pull up older posts by its left side bar.
1helpful
We have a 52" Aquos
Go into the user menu and set the default to full. If this does not correct your issue, then take it to a service center. You are still covered under Warranty.
The word "Factory" has appeared on the screen in red
Hi.
Factory on screen means that the TV is stuck in service mode (Durabrand and more). The problem is fixed accessing Service mode and resetting to factory default settings.
On Durabrand TVs problem is fixed using a programmable remote, entering service code on remote, and accessing service menu.
Procedure is listed on TV service manual.Most durabrand use Menu and key combination 683 to access service mode.
If that does not work, calll manufacturer number to get the key sequence to enter factory menu.
How to reset all adjustment to factory default on KV36FS10?
go to service mode, press 5 & 0 on remote, all data will intilize and default data will be written now save data on memory by pressing mute & 0 on remote.
you need to adjust horizontal, vertical and pin geomatry adjustments after above default data setting procedure to view correct aspect picture ratio on screen.
2helpful
4answers
Looking for a reset code for sharp ar-bc320
The default key operator access code on that machine is 00000
with this code you can enter network settings and change ip and subnetmask to your new requirements.
If this doesnt work you can get keyop password by entering simulation mode and get service report which has user code on it.
Open Questions:
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
