Question about The Audio Players & Recorders
On my Thomas Pacconi Christmas Music Box, how do I get the bottom off of it so I can get to the power because it's pushed in an how can I get a power cord
Posted by Billy Lomaneck on
My thomas pacconi Christmas cd player, plays to fast. Where can I get a manuel
Probably in Spain ??
Joking aside, contact the manufacturer direct
Thomas pacconi # tpc-mse-800-o (no power)why is there no power getting through hole unit?
Since you have no sound even on radio, it's not going to be a bad tt motor. There is no fuse except for a thermal fuse inside power transformer. I would start with a continuity check accross both of the blades on the plug. If it's open, you prob have a bad power transformer.
2answers
Thomas Pacconi TPC-MSE 800
could you include a picture of the under side of the turn table where the belt is fitted?
CD player will not work in my Thomas Pacconi TPC-MSE-800
I have the same unit. Where do you find the screws that hold the cd clamp cover?
5answers
Thomas Pacconi turntable turns too slow
My older Thomas Pacconi turntable was also turning too slowly. Rather than replacing the belt or needle, I tried using an eye glass repair screwdriver to alter the trimmers inside the motor. But the changes didn't take. Then I tried trimming the power to the motor using the larger trimpot next to the motor with the motor itself set to the 78 rpm setting. But the adjustments to the trimmer didn't get the platter to spin slow enough - it wouldn't play an LP. To get the speed down further I replaced the 1K trimmer with a 10K trimmer I picked up for a buck at Radio Shack and successfully adjusted the turntable down to down to 33 1/3 rpm usage. All that was needed was a soldering iron and a 10K trimpot to get the job done.
Speed problem on Thomas Pacconi Turntable
probably need the rollers rebuilt
check out needledoctor.com
Top The Audio Players & Recorders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
