Televison & Video Logo
Why won't my monitor L22W861turn and stay on?
My TV/monitor turns on long enough to say please wait and immediately shuts back off!
Ipod touch won't stay on
First, there are possibility that your iPod just out of battery, not enough to boot.
You might want to turn on and immediately connects to computer or if possible, to the direct charger.
If it turned on, wait for while and then go iTune and restore.
If not, you can at least locate the local apple store and let them take look at it.
They might ask $ for repair but it shouldn't be so expensive.
you might try resetting your iPod (hold down SELECT+MENU for a few seconds) or restoring your iPod back to factory settings in iTunes just to make sure that it's not some type of software glitch?
hope this helps
Screen stays on for about 20 minutes than shuts off after that..if you turn off and turn back on..it comes on then immediately shuts back off Its item #1704FPT 17" Monitor for 4700 Dimension...
On your Desktop, Right Click the mouse and Select Properties.
Click Screen Saver tab and Select Power. Change Turn Off Monitor
to Never. Your monitor should stay ON forever, until you turn its
power OFF.
My monitor will go to black after a while and is
First, try connecting the monitor into another computer to isolate the problem. If it's proven that the monitor is the problem, this monitor needs repair.
I'm not sure if your monitor has a board called inverter. Inverter board is for TV. This is usually the problem once the TV is automatically shutting off after couple of seconds. So, if the monitor has this board, then that could be the problem.
Contact the manufacturer of the monitor for second opinion. But the repair should not cost too much.
Have a great day!
Tv shuts off for awhile then i can turn it back on immediately
hitachi is known for its problems and the best solution is to call a repairman out to repair it properly.i know thats not much help but its the only sure way to fix it and fix it right
Tv powered off and will not stay on. keeps powering off
Not an easy one this. But modern TV's monitor themselves if there is something it doesn't like eg power supply not giving the correct voltage, the TV will shut down. Not really a solution !
Shut off
Does it shut off immediately after turning on? How long after it has been on does it shut off? Can it be turned back on immediately or is there a "cooling" period where you have to wait before it can be powered.
Is this a TV under warranty or is it out of warranty? If in warranty, simply contact RCA and they should help you out.
2answers
On / Off problem
YOUR ON/OFF BUTTON ON THE FRONT PANNEL IS STUCK
SOME HOW (PRESSED IN ) TY SOME WD40 ON IT . SEE IF THAT WORKS.
Top Televison & Video Experts
Marvin
Marvin
