Refrigerators Logo
Question about Magic Chef Refrigerators
Magic Chef Mini Fridge - how do you open the freezer panel?
I need to open the freezer panel of a magic chef mini fridge so that I can access the evaporator fan and the thermostat. But I am unable to pry it open. Is there something that I am missing?
Posted by aamir qureshi on
MAGIC CHEF MCBR 360S Mini Fridge and compressor is not working or cooling. No sound at all from unit. See more details below please. Thank you!
The compressor being hot means it is getting power to it. 2 possible problems. The compressor is locked up internally (too expensive) or the start relay or overload could be bad (approx cost for both parts about $45). You have to decide if you want to risk $50 and still find out you have a bad compressor. Most service techs have a direct test harness to hook up to compressors and make them run without the start relay and overload but not everyone knows how to do it properly.
1helpful
2answers
Hello, i have a magic chef fridge and im trying
It is ok to tilt frige back for hinge access be sure to unplug it and brace it so it doesn't fall on you.
My Magic Chef mini fridge temperature trouble
That can be very difficult to do with a mini refrigerator. There is just not enough separation between the freezer and the refrigerator.
You will likely just have to find a compromise setting and accept the results.
5helpful
My mini fridge will not work. compressor is hot.
Believe you need to change the start relay and overload, Sea Breeze
1helpful
Side by side Magic Chef refrigerator. Freezer
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Could also be begining of a defrost problem.
Magic chef fridge not working
Could also be beginning of defros problem.
2helpful
Magic Chef Mini-Fridge not Working, Model # MCBR360S
Unplug and look for the thermostat control. Try jumping the thermostat wires together. If it runs then replace the thermostat. Also feel the compressor to see if running, they run very silently. Thanks, Sea Breeze
Open Questions:
Top Magic Chef Refrigerators Experts
vince
Marvin
Marvin
Paul Carew
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
