Televison & Video Logo
I also heard a sound like a fuse blowing , could the F06 message be something to do with a fuse?
Posted by Janet English on
David Spradling
    Top Expert:
  • Televison & ... Master
  • 13,229 Answers
The sound could have been a capacitor on the power board
Posted on Oct 03, 2022
SANSUI G-5700 issue need help
I needs professional repair to the item that made the fuse blow.
My 2006 Chevy Uplander rear ac isn’t working. One day I turned the switch on console to off and heard a pop. Since then it won’t turn on.
Sounds like you heard the fuse blow-out.
Have you checked the fuses for the A/c units.?
The fact that the fuse went with a big pop though, may mean that there's an underlying problem in the A/c unit.
Check the fuse & replace it if necessary.
If it blows-out again, it'll need to go to a Chevvy dealer or specialist or an A/c specialist, to find the root cause of the problem.
Best of luck.
Lg 50pm6700 heard a pop, have a blank screen now but do have audio
if you heard eny noise it is blow up something fuse or something on the y-sus board i think it is some transistor or buffer ics one of them
Samsung 5054x/xaa front panel blown? Can I fix this?!
Hi Camomia,
This type of repair could be a bit challenging but possible if the screen is not cracked.
There is plenty of info on you tube for fixing this model number.
https://www.youtube.com/watch?v=V_9glktklhI
My ciggarette lighter worked once now it dosent. When I pushed it i heard a click like a fuse blowing. Do you know how i might fix this? I have a 97 ford escort lx.
If you don't have the owners manual with Fuse Box Diagram and that is not marked, The Lighter would say AUX or Misc or Lighter, the easiest way to find the blown fuse is to check them all one at a time. Since you heard the fuse blow it is the interior fuse not the one under the hood. It may have just been a bad fuse but if you replace the blown fuse and it blows right away then start checking for a grounded wire or if you added and AMP or something and tapped that line look at moving that splice to another line. A common item to splice into this is the Alarm or AMP but there are other items that might have been spliced in like a radio if that is not the factory AM/FM Cassette.
I was baking and heard a pop sound and saw a spark before the oven lost all power? What happened?
OOOPPs - not good , If you saw or heard a pop noise + spark then something blew or shorted.
If the 'loss' was quiet then a fuse or circuit breaker can blow without noise or sparks.
This oven has 4 Heating elements (2 on Grill) 2 inside oven , as you were baking it sounds like a heating element.
As this is a US model I'm assuming you are close to a SEARS somewhere, because they advertise parts made for Kenmore -- try this link http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Evaporative-coil-Parts/Model-867813350/0582/1610510/00007536/00001
Ray
Mic not working on Trust WB-3420 webcam
Open Skype.
Tools.
Options.
Audio settings.
Microphone.
You must choose your microphone driver here.......
If you choose the right one the microphone will work.....
Brother SE-270D dispaly just F06 in LCD Panel
Contact Brother
http://www.brother-usa.com/homesewing/
To the left on the above site is a software download page.
If you need further help.. email brother...they will tell you how to fix this. Takes them a day or so to answer.
Sounds like the technician may have put in a wrong fuse himself. Hoping it was a Brother authorized dealer.
Open Questions:
Top Televison & Video Experts
Marvin
Marvin
