Question about The Audio Players & Recorders
TV randomly shuts off and won't detect external devices
I have a Hisense TV, it randomly shuts off, it no longer supplies sound to my surround sound receiver and it doesn't detect any signals from externally connected equipment. I can only use the apps installed on the TV. Any advice on what parts I need would be of great help. Thanks.
Posted by Jamie Jett on
Hisense 58R6E no sound no picture?
This model had a lot of backlight issues with the lamp strips being bad, order a new set and install them and it will work again, but be careful handling the panel, it's VERY fragile
My Hisense en33926a tv wont turn on and i need help can you help me?
Ok so this one is complicated In my experience with this type of issue if you remove the back of the tv and look for a swollen capacitor as u can see on this pic of what I am speaking of. I had a 60 inch flat screen did the same thing. I opened it up found the one that was swollen and on mine there was only one I removed it desolidered it I went to Apache reclamation it’s a store here in Phoenix that is like a thrift store for machine parts and things like that. I m sure you could probably order one from eBay. Anyway we found the one we need and it was a little larger in size but was the same voltage and soldiered it on to the board and the tv now works. If you think you could take that on go for it. You won’t make it any worse right?
1helpful
Connected jbl bar 5.1 to hisense 65 p7 tv using hdmi arc outlet on tv and sound bar unfortunately no sound
  1. When you connect an external device to TV (without ARC) and Sound Bar, connect the HDMI cable (sold separately) from the external device to the TV. Then, connect the external device to the Sound bar using an optical cord (sold separately).
  2. If you want to connect to just the TV, then the HDMI connection is unnecessary.
  3. I myself find it just as good in not using the HDMI and just using the optical cord.
  4. Take Care all best
Hisense tv picture is upside down, it was working fine
If the picture on the TV is upside down, press the Menu button, then check the following:
? If the Menu is displayed correctly the problem would be a setting within the external source or a signal issue. Please contact the manufacturer of the external device for further assistance.
? If the Menu is also displayed upside down, then the TV will require service..
Why does my Hisense tv randomly shut off
For a TV set to shut off randomly, it generally means that you have to ask for a technician to check its Power Supply Board.
If you have some knowledge about electronic, just open the TV and check for the PartNumber of the Power Supply of that specific model, and do a proper search on Gloogle_Search_Engine related to the same issue: BOARD NUMBER + ISSUE (stop working, works for a few minutes only... etc.) + SOLUTION.
This will offer a better understanding about the problem, so you may be OK to solved it alone.
Information is for all us to share, and you will surely find some about it. Good luck.
1helpful
IWhat's your problem? I have a Hisense LTDN42V68US LCD TV and I am trying to hook it up to a Phillips HDMI DVD Home theater surround system HT53544 my problem is I am not getting a sound I only get so
Good day!!!
Your problem is on your digital cable signal or connection..
Please check all the wirings and connection from the to cable box..
its better if you re insert all connectors and restart all TV,cable box....
Hope it helps...
2answers
Screen will go blank with no audio. It won't shut off with either the remote nor physically pushing button on TV. Only way to get it to turn of is unplug it.
This is a power supply problem, meaning either the power board has a fault or is detecting a fault from another circuit and shutting down. It shuts its self down to prevent further damage too the TV and prevent an electrical fire hazard. I know its probably something you don't want to know.....LOL but have a professional technician service the TV or take it back if its still under warranty.
http://tvtechwork.webs.com/
HL-R4266W shuts down and a faint clicking sound can be heard
I believe I read somewhere that when you open the back cover over the lamp, there is a special little black switch that needs to be in the up position when you put the cover back on, or the TV can shut itself off randomly.
2answers
HTS-GS1 Surround Sound System cannot be utilized for tv.
Check Your TV audio setup,many TV makers out there would like you to turn off the tv speakers in order to use the external speakers.
Joe
Top The Audio Players & Recorders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
