Computers & Internet Logo
My Ario HC3269 has no picture and is flashing red. Tried unplugging and getting no results.
What is wrong and what can i do to fix it
Posted by Teresa Springfield on
Roger R
  • Computers & ... Master
  • 1,698 Answers
Please disconnect any unnecessary wires and restart the tv. If this issue still occurs, please switch power plugs before restarting. Also, double check that you don't have any stuck/pressed remote control buttons that may be causing the issue. Thank you.
Posted on Oct 06, 2022
I have a GE universal remote and need a code for an ario tv ( hc3269) model
Ario is not listed, the best thing to do is use the "Code Search" function of the universal remote to find the code you need.
How can I fix my screen from being cut off on the sides of my ARIO HC3269 T.V?
Look for "format" on your remote control. you will have options like letterbox, stretch, full, etc.. Choose which format is best for you. Mine is currently set to original format and the picture fills entire screen.
How do I program a Comcast xr5 remote control to.an ario tv? cast xr5 remote control to an ario tv?
I am researching, please do not keep reposting. Add all new comments to the comment tab. ty
I need a code for a RCA universal remote for a Ario TV
From Ario Support website, hope this helps!
Cable and Satellite content providers control the remote codes, and we apologize for any confusion during the remote programming. Please try the following codes 10019, 0178, 10178, 0030, 10030, 0835, 10835, or for Dish Network try 627, 659 or 505. For Fios TV (Verizon), try the code 3264. These codes may not work on some universal remotes.
What does a red blinking light on the bottom right corner of the TV mean?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
1helpful
My ario tv has sound but no picture
If you can see an image on the screen when you hold a flashlight to it, the issue is the backlight. Parts and info on this unit are hard to find as it is not a mainstream unit,
Code for ario hc3269 remote
how to fix a crack on the flat screen
11helpful
2answers
Need a universal remote code for Ario tv
From the Ario Website, this worked for me!!!!
"Cable and Satellite content providers control the remote codes, and we apologize for any confusion during the remote programming. Please try the following codes 10019, 0178, 10178, 0030, 10030, 0835, 10835, or for Dish Network try 627, 659 or 505. For Fios TV (Verizon), try the code 3264. These codes may not work on some universal remotes. If there is another code listed for ARIO in your universal remote control guide, please try that code. Refer to the Remote Control Guide under your TV's model number for more information".
Marvin
Marvin
