Where can i get motherboard for my LG MODEL 42PX4MVH-TA
It turns on, with sound but can't display and the technician said there is a part missing that works with the backlight for display.
Its hard to find the component kindly assist me, in love with the television
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Sound like you could of solved a misfire hows the cranking does it sound smooth example ta-ta-ta-tataaa-ta-ta-ta-taaa-ta, that would be a low compression cylinder, recheck the firing order
You burnt out the backlit lamp. unfortunately there is no easy fix for this. If still underwarranty great, if not... it will cost more to fix it then buy a new tv probably.
It definitely has a problem, possibly the Y sustain board and y drivers Up/Lwr. Best suggestion is to take it in for service or have someone come out how has experience with Plasma repair.
