Question about Cambridge Audio Audio Players & Recorders
550C CD player--CD door wont open or close. Gives error message--problem?
Cambridge audio single disc cd player
Posted by paul hackett on
2answers
Cd player error
so is this a stock RAD/cd?
stock JBL 6 disk player in dash>? or? what? name and model #
mp3 and wma format. but not DVD
or
JBL premium 4-disc in-dash CD changer
io the single disc player, 3 kinds sold. new.
and now comes the big question.
TELLS where you got the disk, or name it, or tell how it was made if home made. we dont know that.
is said CD a CDDA? or not. (always try CDDA first)
is CD a real music disc. from a real store, CDDA, is that.
or CDR, or DVDr, or CDRW, or other record-able media
is music MP3? files.
see, the old units dont play modern media.
try 2 real discs, not scratched.
do they play?
one other way, is to name the radio, brand, like JBL then get the
p/n off it. (hard) then look up the product data sheet on it,
bingo, what it can and can not do is there.
but this does it all, mostly
does what yours will not do.
http://www.flyaudio.net/product_id.asp?id=113
I cannot open my cambridge audio 640A compact disc
This is a common issue with all belt-drive cd players, all you have to do is to change that belt and you should be done, or take it to a shop for servicing, as this is a part of a simple service maintenance routine, cheap fix though.
1helpful
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
My cambridge cd player 640c not able to close and keep opening, any advice?
Unless you are an experienced tech, you should let a pro look at this unit. It may be a mechanical fault, or a logic control problem. Cambridge makes excellent sounding CD players, so I think they warrant spending money to repair them properly. Attempts by inexperienced owners can greatly increase the repair cost.
1997 Chevy Pick up Single disc player won't work
Have you tried different CDs?
If the cd is ok, the read head on the cd player is probably covered in grunge! Get thee to ye olde local audio / TV shop and purchase a CD head cleaning kit.
Usually these come with a cd with a brush attached to it and some cleaning fluid.
Follow the instructions on the packaging and give your music cd another try.
Hope this does the trick
M3ODQ
CD player not turning
the tray should have a micro switch to touch when its closed. maybe it needs some fine adjustment. if it doesnt say closed then the laser drive wont start. or maybe the magnetic clamp hasnt come down onto the disc properly
2helpful
Discs stuck inside CD Player. Screen says ''Reading.''
Try resetting the CD (Cambridge soundworks) by unplugging, then repluging. Then hold down the eject button while you turn on the power.
SLIGING DOOR FOR SINGLE CD IS BROKEN
if the door opens and closes dvd player may be faulty
if the DVD tray wont open the disc is stuck inside try Turing it off by the power point wait 3 seconds then back on if disc still doesn't come out (YOU) may need to be remove manually which you need to take it apart
2answers
CD Lid/door catch broken, will not stay closed
Chris, I know it has been a while since you posted this and I don't know if you ever solved your problem but if not....you might want to check out this sight.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313&_nkw=+Cambridge+Soundworks+c1muswke+cd&_sacat=0&LH_TitleDesc=0&_odkw=c1muswke+cd&_osacat=0
[email protected]
Top Cambridge Audio Audio Players & Recorders Experts
ADMIN Andrew
ADMIN Andrew
Are you a Cambridge Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
