Car Audio & Video Logo
Question about Phoenix Gold Car Audio & Video
EQ no power when I add fuse but powers up when fuse is removed?
I have a phoenix gold 9.0 EQ I have my main hot wire tapped into my main hot to my head unit I have my ground connected and my remote tapped yo my amp remote but when I put fuse in for my EQ I lose power but take the fuse out my subs thump real quick and EQ powers up and no sound
Posted by Larry Wooten on
Ovr light comes on as soon as I power up my phoenix gold amp
remove speaker wire a amp, terminals
does OVL come on now.???
test 1 done report.
a CAR amp.
no model told at all.
MX or RX xxxxxx numbers.
etc??? nobody can guess what is in your hands
https://phoenixgold.com/collections/amplifiers
The thermostat light on my phoenix gold iron does not come on can u help.
Probably the power is not received by the heating coil, check fuse near the power cable (inside the flap on the iron bottom), or sometimes there is fuse in the power pulg of the power chord. It is rarely that the lamp is blown
When setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock.
2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq.
3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume.
4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
I have't IR remove control. It's broken. What's can i do to control this amplifer?
You can run a wire from the fuse box to the remote wire at the amp. Find a ignition switched power lead out of the fuse box inside the car that way the ingnition switch will turn the amp on and off .
My Phoenix Gold MX 1230 12 channel amplifier 4 mode buss system keeps blowing the power fuse.
When any amp blows the fuse like this suspect an overload in either the power supply or main amp sections. Most likely caused by a sem-conductor that is acting like a piece of wire. Chances are it will be one or more transistors on the heat sink that's gone.
1helpful
2answers
A FRIEND OF MY GAVE ME A OLD PHOENIX GOLD QX180.2 AMP IM NOT SURE WHICH IS THE THE POWER OR THE GROUND OR WHICH ONE IS THE BLUE WIRE GO THE ONLY THING THAT I SEE IS B- R B+ SO I GUESS THE RED WIRE IS R ...
I'm not familiar with that amp, but normally the power and ground terminals are larger than the rest. Are B- and B+ a lot bigger than the other terminals? It seems to me that power should be B+, Ground should be B- (although usually they are labled something like +12V and -12V or +12V and GND) and the R is probably for the remote wire (small blue wire that runs to head unit)
21helpful
2answers
Power supply connection for pioneer eq-6500
top left - orange.....goes to aux or memory wire
top right - blue.......goes to the remote wire used with amps
bottom left - black.......goes to the ground wire
bottom right - red........this goes to your hot wire
I need to find out the weiring diagrame to install it
Equalizers Like a crossover, the equalizer gets installed between your receiver and your amplifier. The outputs will be preamp connections to your amplifier. You'll find EQs that are designed to be installed in the dash, above or below your receiver. Others are designed to be mounted in a remote location, like the trunk. Either way, the wiring connections required will be the same. To install:
1. Mounting the equalizer:
A remote-mount EQ can be securely mounted with just a few screws. Anywhere between the receiver and the amp is fine. Most people mount the EQ in the trunk near their amp, especially if you have more than one amp. This also makes it easier to add additional amps later. You should mount it where it will be easy to get to so that you can make adjustments without too much trouble. Don't mount your EQ directly on steel — you will invite noise problems. Instead, install it on a non-conductive board and attach the board to the car body (or use rubber grommets under the screws to isolate the crossover).
An in-dash EQ can be mounted above or below your in-dash receiver, assuming that you have space available in the dash. This will require custom installation work. Another option is installation below your dash, in a universal under-dash mounting kit. To install the under-dash mounting kit, attach it to the mounting surface using the supplied self-tapping screws. In most cases, the use of an under-dash kit will require modifications to the kit or to the mounting surface.
3a-xover.jpg Locate the remote turn-on lead behind your radio (usually a blue wire). 3b-xover.jpg Connect the turn-on lead from your amplifier wiring kit to the blue wire. You can wrap the bare wire ends together and cover with electrical tape, or use solder. 2. Making the power connections:Your EQ will require 12-volt power, ground, and turn-on signal connections.
  • To obtain 12-volt power: Cut a length of small-gauge cable (16 gauge is typically sufficient) long enough to reach from the EQ location to your vehicle's fuse panel. Strip one end of the wire, and attach it to the EQ's power input. This may require a crimp-on connector, or bare wire might be sufficient, depending on the equipment you're installing. Route the wire from the EQ location to your car's fuse panel. Using a fuse tap, connect the wire to a source of switched 12V power.
  • To ground the EQ: Remove a bolt near the EQ mounting location. Crimp a ring terminal to one end of a length of small-gauge wire, and then bolt the terminal tightly to the vehicle's metal chassis. Scrape away any paint and clean the bolt location thoroughly. If you can't find a convenient ground screw or bolt, drill a hole for one — be careful not to drill into the gas tank or a gas or brake line.
  • Making the turn-on connection: In most cases, you can tap into your in-dash receiver's amp turn-on lead to get a turn-on signal for your EQ. Remove the receiver from the dash to access the turn-on wire (usually a blue wire). For step-by-step instructions on removing your vehicle's radio, see your vehicle-specific Crutchfield MasterSheet™, or read our In-Dash Receiver Installation Guide. Strip the insulation off a small section of this wire coming from the radio. Strip the insulation off another small-gauge cable that's long enough to reach from the in-dash receiver to the EQ, then connect the two with crimp caps or solder. Wrap the solder or crimp connection with electrical tape to guard against a short. Using wire ties to secure the wire, route the turn-on lead behind your dash all the way to the EQ mounting location.
3. Making the signal connections:
In most cases, you'll be routing RCA cables from your in-dash receiver's preamp outputs to the inputs of your EQ. While your receiver is out of the dash to access the turn on lead, connect a set of RCA patch cables (long enough to reach your crossover in its mounting location) to these outputs, taping them together so they won't come apart. Route the patch cables (again using wire ties) behind the dash, and to the crossover mounting location.
Top Phoenix Gold Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Steve
Tom Chichester
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
