Televison & Video Logo
Can't access TV main menu from both remote and multifunction standby button on JVC smart tv
Need to setup HDMIARC to output sound to soundbar Switched off and unplugged Changed remote batteries Reset TV to factory settings Nothing helps - completely helpless
Posted by Clayton Joseph on
Does the main board of a Samsung 55" LED TV, (Model # LN52A750R1FXZA),control/provide for sound output? Have lost sound on my TV.
Hi Walt, check in the TV menu, if the audio output you are using is assigned
Hola Walt, verifique en el men? del televisor, si esta asignado la salida de audio que esta usando
My new Vizion tv has a vizion sound bar, the sound comes out with an echo, how do I correct?
Your TV speakers should be turned all the way down or off when you use a separate sound system such as a soundbar. Using them with the soundbar may cause echoes and the TV speakers do nothing to improve the sound.
Look at your TV's audio menu. If you can, turn the TV speakers off completely at the menu. Also see if you can set the analog audio output to "variable." This will allow you to control the soundbar's volume with the TV remote.
1helpful
There is audio output jacks on back of tv i plugged the red and white from soundbar and still no sound
It may need to be turned on, go into the main menu of the TV and look through the Audio setup menu.
Vizio sound bar won't turn on with tv
How to Fix the Vizio Soundbar ' Chron.com
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
Soundbar Won't Turn On ... Turn the volume up on the Vizio soundbar and also ensure the soundbar isn't muted. ... For example, even if the Vizio soundbar is connected properly, if the TV is set up to output through the internal speakers only, ...
Fix A Vizio Soundbar Remote In 4 Simple Steps ' Vizio TV ...
vizhdtv.com/fix-a-vizio-soundbar-remote-in-4-simple-steps/
Aug 25, 2015 - Each model of Vizio soundbar includes its own remote. It's what is ... Use the power button on the soundbar to turn it on. Then test ... So replacing thesoundbar won't resolve the issue if you have one of the effected models .
I have a Sharp Aquos LC-60LE640X TV and I am trying to connect a Samsung HW-H751 Soundbar to it. I have hooked up the optical cable, adaptor and sub woofer, I have tested the Bluetooth function throug
If you are connecting the soundbar to your TV with the digital audio cable, make sure to select "D IN" using the source button on the soundbar. Bluetooth (BT) is a separate source from another device. (phone, etc.) The TV will need to be set to use the digital audio output and probably PCM format. (?) The subwoofer is preconfigured at the factory to mate up with your soundbar. (See below instructions - your soundbar includes the amplifier:)
Digital audio output setting:
After connecting an amplifier with digital audio input and
external speakers as shown, you should set an audio
output format compatible with the programme you are
watching or the device connected.
Go to "HOME" > "TV Menu" > "Setup" > "Option" >
"Terminal setting" > "Digital audio output" > select
"PCM" or "Bitstream".
NOTE
• When set to "Bitstream", Dolby Digital is output when the Dolby
Digital or Dolby Digital Plus audio formats are received. When
set to "PCM", PCM is output no matter what audio formats are
received.
• When set to "Bitstream", HE-AAC audio formats can be output
as Dolby Digital.
I have connected Bauhn 2.0 channel soundbar to my Samsung smart 3D HD TV. But it does not work.
There is probably a sound setup menu on the TV. It needs to be switched to the soundbar. :-)
PhillipssoundBar htl2101A
You have to use the TV remote to set the TV sound option to external. Look on TV setup menu for 'external output' or 'external speakers'.
I HAVE A 50" EMERSON T.V. AND I HOOKED UP A SOUND BAR TO IT AQND I DON'T HAVE NO SOUND
Ensure that the output from the TV is feeding the soundbar. Use Settings/Sound/Output in the Main TV Menu.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Lg soundbar nb2020a setup
If you are currently using your sound system shown for your television sound then you need to use that with you sound bar plugged into it. You can hook it directly to your TV if you have an audio out but your tv has to produce enough output to run the sound bar. If your tv does have an audio out then there is a good chance you need to make those jacks active in the sound set up menu for external speakers. Some sound bars are powered and will require being plugged in as well.
4helpful
2answers
Sound got off even sound menus in TV
It is really a memory problem try to access its service mode open the cover of its remote control so you can find an extra carbon switch inside which is not accessible if the remote control's cover is on.Another way is you can use an eeprom copier copy a known good aiwa ctv with the same model or parameters
Open Questions:
Top Televison & Video Experts
Marvin
Marvin
