Computers & Internet Logo
Question about Corel Computers & Internet
When I am trying to open my Corel Word Perfect 8 I get a mesg G180.dell? How can I solve this problem?
Posted by Charles Kurtmen on
Tesfay
    Passionate:
    Visited the website for 10 consecutive days.
    Novelist:
  • 139 Answers
There are a few things that could be causing this problem. One possibility is that your Word Perfect 8 installation is corrupt. You can try uninstalling and then reinstalling the program.
Another possibility is that there is a conflict with another program on your computer. Try disabling or uninstalling any other programs that you have running. If that doesn't work, you may need to contact Corel's technical support for help.
Posted on Nov 22, 2022
How fix - corel photo paint 8 on vista crashes
Try these...
1. Check the compatibility of the version that you have with operating system.
2. Change the compatibility mode for all users.
If all that does not help..... Try to find help and solution from here
Support for Corel 1 800 345 0735
I am unable to open my program corel video pro X2
could be a path issue
try it this way
start button
all programs
find corel video
open from that end
2helpful
4answers
I have used CorelDraw 8 for years, and the clipart worked fine, even with Windows XP, but I installed CorelDraw X4 and installed it. But after Installing CorelDraw X4, I could no longer is CorelDraw 8...
I had a similar problem with Coreldraw 8. I used it successfully for years and loved it on varoius version of Windows, currently XP. I installed Coreldraw 12 and still had Corel 8 on the computer.
Now the problem: Corel 8 and Corel 12 could not open the Corel 8 clipart disk #2, only just down to the folder level. When I right clicked on the Corel 8 disk #2 clipart folder and checked the Path Properties it gave me a path other than the correct clipart disk location (in my case it should have read E:) BUT it was some weird location like
MNfisherman referenced above and read: C:\Documents and Settings\All Users\Documents\Corel.! What the?! I knew the path should have read E: to access the clipart since the clipart was on the disk and in my CD tray, so I uninstalled Corel 12 thinking that was the problem since 8 had worked fine, then checked the clipart CD again but still no luck.
I then uinstalled Corel 8, so now I had no Corel program on hard drive. I put the Corel 8 clipart disk #2 in the computer knowing it would not open the clips but just to see if I could get beyond the folder level to see if the clipart files were there and yes I could. (I could only read the names of the files at this point because no Corel on computer) So I only reinstalled Coreldraw 12 figuring the later version would open the older version clipart and Success! It worked. I think my problem had something to do with the Corel 8 MF indexer, but I'm not sure. I had a red semi circle (like the Corel Set Up Semi circle) on all of the clipart folders instead of the regular yellowish fold so thats why I think it had something to do with indexer or other type of setup conflict). Now all of my clipart folders appear normal being the regular yellowish color folder.
I suggest using a clean slate by unistalling all versions (Make sure you shut down the computer after each uninstall to get rid of all of the components of the program and then restart the computer) and then only reinstall the newest version. Hope this helps. Good Luck
1helpful
My Corel Draw 8 locks up when I try to save my project. Any suggestions. I am using Windows XP
I have seen this under XP SP3. The following solved the problem for me.
Install Corel 8 from the CD. Reboot.
Get the 369 and 433 upgrades from the Corel FTP site. (Those upgrades are no longer available on the web site, but there is a pointer to the FTP site on the "Updates and Patches" page).
Apply the 369 patches. Doesnt matter what version the CD is -- the patches check to see if they need to be applied. Reboot.
Apply the 433 patches. Reboot.
Start the XP Compatibility tool. Make the settings for PhotoPaint and Draw "Windows 2000", "No XP Themes." Reboot
Kyocera FS-2020D Driver maybe not compatible w/WP 8
To verify it is a driver issue you can uninstall the printer driver and see if you get back the lost functions. If you do then it is a driver issue. I can't say I have run in to this before.
Home vista to open corel files
If you try to open the file with Microsoft Word, it should automatically convert it. To open it with Microsoft Word, hit "File" > "Open". Change the "Files of Type:" drop down box to "All (*.*)". Navigate to the folder in which the file is located, and it should appear in the dialog box. Double click the file, and Microsoft Word should convert the file for you. You can then save the file in a different format if you prefer.
Top Corel Computers & Internet Experts
David Shaub
Marvin
Marvin
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
