Computers & Internet Logo
Question about The Computers & Internet
My Aficio SPC430dn is not responding to print control now, say 'printer not responding' any idea why?
I recently moved house, I have been using the Aficio SPC430 for years with no problem, now none of my Macs that previously worked with it will connect. OS Snow Leopard or OS Monterrey
Posted by Nick Webb on
  • The Master
  • 6,555 Answers
How is the printer connected to your computers? If it is connected to the network, your router may have changed the I.P. address for the printer. Try reinstalling the printer using the latest driver software on each computer If you need the software, see https://support.ricoh.com/bb/html/dr_ut_e/rc3/model/spc430/spc430.htm .
I know that I had to reinstall the network drivers for my printers after changing routers. The two routers used different default router I.P. addresses and thus assigned I.P. addresses in unique ranges. The computers didn't get the data on the change until the software searched for the printers.
I hope this helps.
Posted on Oct 01, 2022
2answers
Ricoh Aficio SPC430DN and my 440DN have error codes of SC681-06. Help!
I have a photo copy machine gestetner model 3722 td this error on the screen how we will remove it
My printer is not responding or printing when giving print command
You are either using the incorrect driver or driver port settings. If this is all correct then you could have a faulty controller.
How do i remove the paper from the duplex unit when there is no paper there
You could have a broken actuator or the spring came of. I would check all areas for paper not only the duplex area. I've seen paper jams in other areas show a different indication on the display.
Aficio 1027 only print first couple of pages
Could be several things. I would start by eliminating the easiest things. Try another cable, decrease dpi settings (less memory usage), try a USB cable to see if theres a difference if a port is available. Update the print driver from Ricoh website.
3answers
SPC 430 DN. How do I correct error code SC 315?
Consult the owner's manual troubleshooting section. Search the internet for:
Make + Model + the words "SC 315"
Form feed message
if ur using print servers
check properties for print permission or promt for print
2helpful
Ricoh Aficio 2018 ink rubs off paper too easily
Your corona wire is not function properly ... dirty or broken ... and/or the heater is not up to par.
Replace the corona and the heater roll to fix this problem.
1helpful
Ricoh CL7100- Black Dots on all printouts
What are the correct colour settings for optimum colour printing for Ricoh Aficio Cl7200
2answers
Ricoh Aficio CL800 - Set Transfer Roller
possible transfer roller rotation sensor dirty or damaged transfer roller. check -- open rear door and see how the roller looks.
2answers
Toner problem
R u using gen OEM toners?
Top The Computers & Internet Experts
vince
NADARK
NADARK
A Kisling
A Kisling
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
