When turn on power to heater unit turns on then turns itself off with error 11 flashing. how do I fix?
Posted by Francis Nicolette on
Roger R
  • Office Equip... Master
  • 1,742 Answers
if your heater is gas based, please check that the gas supply is turned on. Also, I would reach out the manufacturer if the above information does not completely stop the error. Thank you.
Posted on Oct 01, 2022
I have a Noritz tankless water heater (model n-132m). I am getting an error code of 71. What does that mean?
The Noritz Manual shows fixed for the following error codes:
11
21
90
99
For all other codes this is the recommendation:
Contact our sales agent if:
• Any other error code appears.
2answers
Whay does my AIWA CA-DW63OU start playing by itself?
are you sure it's not going into demo mode after you turn it off? Is there just lights and display flashing? - that is demo mode. Probably a button on the remote to turn it off.
1helpful
2answers
Replaced mother board due to error code c2 11 as per rheem tech department. now code 11 flashes after 3 to 4 minutes of use and unit shuts off. WHAT NOW????
Rheem, Richmond, Ruud, and Paloma are all the same manufacturer. After about 9 months, my tankless RTG-74PVN started giving me error code 11 and cold water!. I fixed it by cleaning the burner, as shown in this video:
www.howtolou.com/clean-a-burner
3helpful
For the past couple of weeks, when we try to use hot water in the morning the system shuts off. The error message we get is C7. Often we can turn off the control panel, turn it back on again and then it...
Sorry to read about your problem, I hope this helps you out.
Turn the power off and remove the cover. Find the two terminals that the remote control connects to and disconnect the remote control wiring. Turn the power back on and open the hot water tap and see if the unit comes on. If it comes on, this is a problem with either the remote itself or more likely the wiring between the remote and the tankless unit itself. Without a remote it will control to 120 degrees F. and will run without the remote.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
3helpful
2answers
Rinnai 1004 F Error Code 11
Code 11 is that the unit is trying to light but does not sense a flame after 5 seconds. Usually means you have run out of gas if you are bottled gas. Check your bottles are turned on if you are on LPG, you might need to change over manually. Have you anything else on gas?
I have error code e000003-0000. How do I get it working again
This is a Heater temperature error, caused by an abnormal drop, or low temperature detection.
It is most likely a blown heater element.
The main thermistor reading is lower than 140°C when paper is moved.
Main cause can be the fixing film unit is faulty (i.e., the main thermistor (TH1) has poor contact or has an open circuit; or, the fixing heater is faulty). or,
The main power supply PCB is faulty. or,
The DC controller PCB is faulty.
Caution: The following steps should only be carried out by qualified people...
To clear the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
CAUTION
Do not clear the error until the fault is repaired. If you clear the error, and there is still an electrical fault it may result in a fire!
Turn on the power switch, and clear E003. (Service mode) Thereafter, turn off and then on the power switch. Does the fixing heater operate?
No? Try checking...
2. Wiring
Is the wiring from the DC controller PCB to the fixing film unit normal?
NO: Correct the wiring.
3. Fixing film unit, DC controller PCB
Try replacing the fixing film unit. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Good luck
3helpful
2answers
E000732-0001 Error Message
E732 Error code details
  Main cause
 The cable connector has poor connection. The reader controller PCB is faulty.
Condition
 0001 The main controller PCB detects a fault in the communication between the reader controller PCB and the main controller PCB. Connectors
1) Connect the cable [1] for the environment heater.
ir7200-f04-309-01_e.png 2) As needed, connect the reader unit anticondensation heater cable [1].
ir7200-f04-309-02_e.png PLS RATE ME!!!!!!!THANKS MATE.
4helpful
2answers
System Error E000 and E003
E002 Error code details Heater temperature error (fails to reachspecific level; inadequate increase)
0000 The temperature of the fixing film is as follows:
1. has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
2. has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
3. has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
Main cause
 The fixing film unit is faulty (i.e., the main thermistor TH1 has poor contact, or the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty.
Caution
 To clear the error, execute the following in service mode: COPIER>FUNCTION>FCLEAR>ERR.
Action
 See the description for E003. E003 Error code details Heater temperature error (abnormal drop; low-temperature detection)
0000 The main thermistor reading is lower than 140°C when paper is moved.
Main cause
 The fixing film unit is faulty (i.e., the main thermistor (TH1) has poor contact or has an open circuit; or, the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty.
Caution
 To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
Action
1. State
 Turn on the power switch, and clear E002/E003. Thereafter, turn off and then on the power switch. Does the fixing heater operate?
 NO: See "The fixing heater fails to operate."
2. Wiring
 YES: End.
1helpful
Error code F-46-11 in my photocopier konica minolta 7035
A 46-11 code indicates a communication failure between the A/D converter board and the main control board. Likely a bad or poorly seated ribbon cable. Try to reset the machine by turning off the main power switch on the side of the machine for 10 seconds and re-powering up. If the problem persists you will need to call a technician.
3helpful
Rinnai 1004 error code 11
I had this problem and oops, the gas intake was closed. check the door on the right side of the unit, and make sure the valve is turned to "open" .... here's the link for the online manual if you want it: http://lib.store.yahoo.net/lib/hectors876/1004om.pdf
Marvin
Marvin
