Video Cameras Logo
Question about Canon Video Cameras
Am I wise to try and fix my [NTSC] Canon ES2500A video camcorder myself or should I just try to replace it with a refurb to transfer my Hi8 video to digital?
The Camera gate opens on start and closes but play, rewind etc. functions do not work. I'm guessing a servicing to ease any stiffness might do the job to get it to at least play a tape. Is their any video guides to self service these cameras or is it worth it at all to send it away versus buying a refurb?
Posted by Michael Bass on
Roger R
  • Canon Master
  • 1,742 Answers
you might be able to get the camera fixed by geeksquad/Bestbuy so I would advise you to try this first before purchasing a replacement. Thank you.
Posted on Oct 01, 2022
1helpful
Play back pre recorded HI8 tapes on my TRV130?
The Sony DCR-TRV130 is a D8 digital camcorder which is not compatible with Hi8 camcorders.
You need to have an Hi8 camcorder or DCR-TRV103 or similar camcorders that backward compatible with Hi8 camcorders.
I have a canon ZR60 camcorder with a "black
Yes, these units in particular have a common problem with the CCD sensors. It is not exactly an inexpensive repair, and if you had to pay for it yourself, would probably exceed the value of the camera. Contact Canon support as they may replace the CCD for free or under a special warranty, since the problem was so pervasive. If Canon won't replace it for you, you probably need to look into a new camcorder.
I am using an old, borrowed Canon NTSC Elura 100 camcorder with a Mini DV 60 tape. I do not have the original Picture Package software or the manual, and I am trying to transfer onto my computer, which...
You can download the manual, software, and more from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/camcorders/minidv_camcorders/elura_100
1helpful
Canon ES5000 hi8 camcorder won't load a tape.
that is the mechanism alignement(mode switch)
plus a little gear who match with the other
you will need a very good tech to fix it.usely its the problem.
hope that will help
regards Alan
Its an old video camera. i want to put these videos from my sony handycam vision ccd-trv43 ntsc hi8 camera onto my computer. Please help!
You you need to transfer then through the dv jack, so you will need a d8 sony camcorder, or similar. Larry's Electronics
Canon NTSC ZR25 MC Digital video camcorder eating tape how can I fix it
Canon NTSC ZR25 MC Digital video camcorder is eating the tape. I've loaded a new tape and get an "eject tape" message each time. Does anyone know how to fix this issue?
Downloading Canon ES8600 Hi8 movie to Macintosh
Just connect the camera to you Mac by using Firewire.
Hello to everybody; how can transfer my video
Your camera should be USB so just find a usb cable and plug it in.
You computer should reconise it as removable media and you can broswe your files there.
If its a memory card camera you can just buy a memory card reader and plug this in
hope this helps
alex
10helpful
2answers
Sony TRV510-playback, audio choppy, image isn't clear
I was having the exact same problems, and I read a post on this website somewhere recommending that I just record a few seconds of video on a blank portion of tape and then the camera should start playing video normally again.
I tried it, and IT WORKED!!
Transferring Hi8 to my PC
Download Driver
http://esupport.sony.com/US/perl/swu-matrix.pl?upd_id=1452
Install then download and install a video program like movavi videosuite or ulead videostudio (i personally recommend movavi).
Plug in the camcorder and switch it on, put it on play/edit and play the video, press record or capture in the software and let it record!
once the video scene in the camera is done, stop the recording and do what you wish!
GOOD LUCK!
Top Canon Video Cameras Experts
NOEL
NOEL
Lawrence Oravetz
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
