Computers & Internet Logo
My pagemaker 6.5 files did not open in 7 error - insufficient memory
Posted by vishakha rane on
Roger R
  • Computers & ... Master
  • 1,698 Answers
Please check that your hard drive is not full. If not, you can restart your computer. Otherwise, you might need to remove some data from your hard drive. Thank you.
Posted on Oct 01, 2022
Pmd to pdf
PMD stands for Adobe PageMaker also called PageMaker Document. You can down load PageMaker free from Adobe. https://www.adobe.com/cfusion/tdrc/index.cfm?loc=en%5Fus&product=pagemaker Have a Nice day.
2answers
Corrupted Pagemaker .pmd file
Page maker 7 files showing hoops can we repair that files
ON INSTALLATION OF TRIAL VERSION OF PAGEMAKER 7 ERROR MESSAGECOMES SAYING ERROR 115 PLEASE ADVISE
Issue
Error 115 when installing Adobe FrameMaker 7.0 or 7.1 on Windows
Solutions
Do one of the following solutions:
Solution 1:Disable anti-virus applications, and make sure all 3rd party applications are closed before installing.
Solution 2:Copy install files to HDD are run setup from that location (Frame installer lives in FM directory)
Solution 3: Remove all files from %temp% and %windir%\temp and reinstall
Background information
Error 115 from the InstallShield help reads as follows: "Specified file cannot be opened as write. An attempt was made to overwrite a locked file belonging to a file group that does not have the Potentially Locked or Shared property set to Yes; an attempt was made to install a file with a long file name (or to a folder with a long path name) in a 16-bit setup; or the path to the target folder is invalid."
17helpful
Plug-in error (7212) (6176)
I am getting the following error when i try to open Pagemaker 7:
Plug-in error plug-in cannot be completed. some system operation failed [7212] [16]
Isass.exe system error keeps coming up, insufficient system resources exit to complete the API
1. Remove all viruses or spyware or worms, if there are any.
Open Task manager and check how much physical memory and PF (Paging file) is being used.
2. If usage of both physical memory and PF (Paging file) is high
Click start>> Control Panel >> System >> Advanced >> Performance Settings
3. Click on Advanced tab and click Change under Virtual Memory.
Click Custom size and set the Initial size to 1.5 times of the RAM size on the computer and Maximum to 3 times.
4. Restart the computer
5. Empty some memory space on the "C" drive
6. Click Start >> Run >> Type CMD >> Click OK
7. In command prompt type "chkdsk /r" press "Enter"
8. Type "Y" and press "Enter"
9. Restart the computer
10. Also if you want you can defrag
Huge black spot over my pagemaker files
I installed version 6.5 of PageMaker as I was having problems with the 7 version. I am going to give you a link and suggest you try the following. Go to C:\Program Files (x86)\Adobe open your PM files and delete them all. unzip the files and put them all into the folder. Rename the folder PM65. In the folder open the application icon and it should load. the file is of course PM65.rar. The website is completely safe. It is my own web. Good Luck
http://tricia8765.fatcow.com/Programs.htm
2helpful
2answers
4helpful
2answers
Translate a pagemaker file into indesign
This is from Adobe InDesign (CS3) Help module:
Convert PageMaker documents InDesign can convert document and template files from Adobe PageMaker 6.0 and later. When you open a PageMaker file, InDesign converts the original file information to native InDesign information. InDesign files are saved with an .indd filename extension.
For more information, see the PageMaker Conversion Guide (PDF) at www.adobe.com/go/learn_pmconv. Before opening the document in InDesign, you may want to do the following:
  • If the PageMaker file or its linked graphics are located on a network server, floppy disk, or removable drive, it may not open as expected if an interruption in data transfer occurs. To prevent data transfer problems, copy documents and their links to the hard disk, preferably in the same folder where the PageMaker publication is stored, before opening them in InDesign.
  • You may want to use Save As in PageMaker to clear unnecessary hidden data.
  • To ensure that all links are maintained, copy all linked files to the same folder where the PageMaker publication is stored.
  • Make sure that all necessary fonts are available in InDesign.
  • Repair broken graphics links in the PageMaker publication.
  • If you have a problem converting a large PageMaker document, convert portions of the PageMaker file separately to isolate the problem.
If you cannot open a corrupt PageMaker document in PageMaker, try opening it in InDesign. InDesign can recover most documents that PageMaker cannot open.
1helpful
2answers
Marvin
Marvin
