Televison & Video Logo
Question about Sanyo Televison & Video
Yamaha HTR-6240 shut down when it opens with click sounds
So after checking my amplifier I found a component called Sanyo stk433-330 that cause the problem, i wanted to know, where exactly can I find this component . and if i changed with a different version it will cause a problem?
Posted by Ayed on
1helpful
You will find it has a power amplifier issue. Take it to an authorised Yamaha repair centre.
2answers
My yamaha htr-5640 receiver will turn on for a sec then a small click and then shuts down....no speakers hooked up....what is the deal?
With the power off, try to disconnect every component and then power on the receiver. If it still shuts down, then it is an indication of an internal error and the unit needs to be serviced.
Regards,
Yamaha Support
I have a yamaha htr-6160 AV receiver. I have hooked up my DVD to it using using component video cables but I can't sound out. Video no problem but no sound.
it is sad your having a sound problem with your Yamaha
to resolve these problem , check the audio out settings of your DVD
player, it might have been set to digital and not analog.
2helpful
Yamaha RX-V3000's front channels quit working
The front channels could still go out if one of them
is going out as the relay will shut em both down if it senses a problem! Check also for bad solder connections too!
What could be causing the power to cut out on our HTR 5940 receiver
somewhere along the way something is shorting out.
First I would check the impedance of your speakers most common are 8ohm speakers and these can be driven by most amplifiers.
Some brands of speakers are 4 ohm and even less are 2 ohm. These lower resistance speakers put a great deal of strain on most amplifiers and may cause them to go into "protect" mode and temporarily shut down.(less resistance requires more ampsrage to drive them)
Next thing to check is to make sure that none of your speaker wires have any loose strands that may be shorting out either at the speaker terminals on the amplifier itself but also behind each speaker.
Another test would be to connect 1 speaker at a time and turn the volume up to see if perhaps the short is being caused by 1 particular speaker or 1 particular channel for example it may be your front left amplifier that is failing causing the entire system to shut down.
If you can't diagnose the problem on your own you may have to have a service tech look at it. I always caution people to first establish a "value" on any item that may need repair and then decide the maximum amount of money you would invest in repairing the unit Taking into consideration that 1 hour of labor and a relatively inexpensive part can easily add up to $100 to $150.
In the past when I have had similar issues it usually came back to being something basic that we overlooked in the installation, Ie: a bad cable loose connection etc.
HTR-5890 receiver keeps shutting down
for the past month i have been shopping for the perfect home theater system and have narrowed it down to a bose system,a sony system and a paramax p510...i have listened to all 3 systems and have found the paramax to be the better system not a cheaper system but seem more bang for my buck at 3200$,a very powerful tube amp and downfiring sub maxes out at 2000 watts...
1helpful
Yamaha HTR-5830 Video shut down.
You have having a problem with the video amp clipping the signal after it get hot. You have one way to try to temporarily solve this problem. Try putting more air flow over your receiver and cooling down the temperature inside the receiver and see if the video amplifier starts working correctly. If it does then you must put a fan on it somewhere that will keep the air flowing so the video amplifier is not allow to overheat. If this does not solve the problem, then you will need to have the amplifier replaced for it to work correctly. If the unit is under warranty then call this number 1-800-492-6242 to locate a service center in your area. Call them for help with your problem. You can also try looking on the www.yamaha.com website. Put in you model number and check in the frequently asked questions and troubleshooting sections for people who have had similar problems with this unit and see if they printed a solution for the problem. I hope this helps you with your problem.
2answers
My y amaha v star 2001 shuts down when it's running
try cleaning your fuel tank vents. sounds like it is clogged and causing the fuel to vapor lock.
1helpful
Yamaha HTR5830 shuts down when any front panel button is pushed
You are having a component failure problem in the switching circuit. This unit should be taken in for service. Since it is going into the protection mode on any switch operation the failure is serious and needs to be repaired before it causes more damage to the receiver.You can call this number to find a Yamaha service center near you. 1-800-492-6242. You can also go to the www.yamaha.com website. go to the support section and put in the model number of your receiver and check out the frequently asked questions and troubleshooting sections to see if someone else has had this problem and had a repair solution printed. I hope this helps you with your problem
Top Sanyo Televison & Video Experts
Jaime Hernandez
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
