Televison & Video Logo
Does a FRC board fix no picture on TV?
Hello I just recently purchased RCA/Westinghouse LJ94-38081C T-Con Board for my TV I'm trying to repair. It has light coming through but no picture. I watched some YouTube videos and did a flashlight test to see if I could see picture. I saw nothing so it made me think the t-con board was faulty. Turns out, when I put the new t-con board I ordered in the TV still nothing happened it looked the exact same. My guess is its the FRC board. Could you give me some insight before I try again?
Posted by Caden Scott on
2answers
Westinghouse tx-47f430s LCD TV...Picture Solarized
Shop Jimmy is the place for all the spares
ShopJimmy: TV Parts, Universal TV Stands, TV Repair
https://www.shopjimmy.com
The online leader in TV repair, replacement TV parts, DLP lamps, Universal TV Stands, LED Strips & more! Fix your LCD, LED, Plasma or DLP TV today!
TV Parts
Shop our replacement TV parts to repair your TV today!
But have a read of this tip I wrote.
https://www.fixya.com/support/r29790007-repairing_own_television
How do I replace control board?
RCA/Westinghouse HV320WXC1007061 T-Con Boards ...
? 4:35
https://www.youtube.com/watch?v=5jO_TZfplR0
Jan 21, 2013 - Uploaded by ShopJimmy.com
RCA TV Repair Westinghouse TV Repair T Con Board Tutorial & No Picture ... Top Common LCD TV problems for bad TimingControl T-Con Boards: .... VR-3215 with no picture no sound but the power LED is solid green, any ...
RCA 276046 Power Supply Unit (PSU) Boards ... - YouTube
Vertical colored lines on entire screen, sound ok
Hi.
Probably the t con board of your TV is faulty. T con board is the one which drive the lcd pixels. You have to replace the T con board to get it work properly.
Here i have added the picture of the T con board of your tv for reference.also added the video to know how to replace the T con broad.
RCA L32WD22 T-CON BOARD UT-5531T03088-76J
Samsung TV Repair How to Replace Con Board in LJ94 02 705E Model How to...
www.electro-medical.blogspot.com
Westinghouse Flat Screen Goes Blurry/has Scrambled Picture
tried first with re seating the lvds cable in the t-con board, the t-con board is mounted covered with metal shield. if can get with fixing the cable, then your t-con board has defective component parts.
Westinghouse tv greeen and pink
Hello, this symptom is normally caused by several things. The most common one is the T-Con board. This can be caused by over heating in the unit which will cause the T-Con board to go bad. Once this board is replaced it should all be okay. For more information on getting this problem fixed as well as live troubleshooting, please email me at [email protected]
Westinghouse ltv-46w1hd I have sound no picture was advise it could be the backlight inverter how can you tell if it bad.
I have a Westinghouse 46" LTV-46w1 HD and it turned out to be the T-Con board which I found a used replacement board at Shop Jimmy’s. It cost around $70.00 with shipping. My TV was purchased in 2006 and it running better than ever… again!
I have a Westinghouse tv the color keeps changing.
Hello, most likely based on the symptoms you will need ether of two things, one the T-CON board which is the timing control for the unit, or the main board. You can find parts at [email protected] which I would recommend to email them first as you can request a call back from a Westinghouse technician so you can be sure that is what you need, and another place you can purchase parts from is www.shopjimmy.com.
My Westinghouse LCD tv starts out fine, but after a while the screen starts to roll so rapidly that you can't see the picture.
Hello, with this model there are two thing you can do. One its the cheapest which could be causing the problem, this would be the LVDS cable, this cable runs from the top of the main board and in to the T-con board hidden under the main board. What tends to happen is that adhesive in the tape that holds that cable wears out with the heat and over time the connection comes loose, the way to fix this is to replace the tape with foil tape found at your local hardware store. The second thing that can cause this is the main board which you will need to purchase and can find out the price and availability by emailing [email protected]. Hope this information is useful, if you need information of how to repair the LVDS cable I have a sheet on how to do it including pictures. Please feel free to rate me if my help was useful.
Ltv-40w1 hdc has sond but no picture
Yes, I have the T-con board for $80.00 for that TV.
Mine has a broken screen... kids knocked it off the stand. So I have been striping it for parts to sell. I still have the T-con board and will give a warranty that is will not be DOA.
[email protected]
Top Televison & Video Experts
Marvin
Marvin
