Televison & Video Logo
Question about Zenith Televison & Video
My zenith CD/DVD duplicator LCD light on but no ready
LED light is on but not ready
Posted by Abba Ayenajeyi on
Hi, I have a Wytron DVD-3000 which will burn DVDs but does not burn CDs. Loading the master CD disc produces no data display in the led screen. Any ideas?
It appears to be a DVD writer not a CD Writer. It also says it depends on the drives that are used..
The Wytron DVD3000 duplicator controller can be used to create exceptional multi-target standalone DVD duplicators with superb reliability and performance. One of the most reliable DVD duplication controllers around.
Copies both DVD-R and DVD+R and DVD+R DL depending on drive fitted.
  • Copies a full-capacity 4.7Gb DVD-R in ~10mins (at 8x)
  • Supports up to 9 DVD writers.
  • Easy to use - requires no training.
  • Stand-alone operation - does not require a PC or software.
  • Copy From DVD-Rom or Hard disc (optional).
  • You could ask the maker?
    https://www.wytron.com/blu-ray_dvd_cd_burners.html
    3helpful
    Acard duplicator - 'Source drive not ready'
    > source drive not ready
    When you push the button to open/close the drawer, does it work,
    i.e., is there electrical power reaching the drive?
    Did you put a disk into the "source" drive?
    Is the same disk recognized when you put that disk into any other computer?
    If so, then the "source" drive is damaged, and needs to be repaired/replaced.
    1helpful
    Target drive not ready
    The error message "Target drive not ready" indicates that there is a problem with the blank disc inside the writer drive(s) of the duplicator. In order to solve this problem, please insert brand-new blank media into the writer drive(s) and press the ENT/OK button twice on the duplicator. If you are still having problems, please feel free to contact us @ 888-686-8868 x208. Thank you for your inquiry and thank you for purchasing EZ Dupe products.
    EZ Dupe Technical Support
    My ACARD Technology Pro DVD duplicator is giving me a "Target Drive Not Ready" message and will not duplicate. What can I do?
    My ACARD Technologyicon1.png Pro CD/DVD duplicator is giving me a "Target Drive Not Ready" message and will not duplicate. What can I do?
    1helpful
    2answers
    I put a dvd in the dvd rom and blank dvds in the other and hit copy and it goes to preparing and the says that the source is not ready.
    The "Source Drive Not Ready" error message indicates a problem with your master disc. There is a function on the duplicator called "Prescan" on the duplicator that can check your master disc to make sure it s a "good" disc suitable for duplication.
    Hope this helps and if you have any other questions, comments or concerns, please contact us @ 877-686-8868 x208 for technical support.
    TEAC DVD Duplicator copies CD but not DVDs
    your DVD ROM's lens has became weak.
    and it cannot be repaired.
    But if you manage to open the DVD ROM clean the dust in it & it will start working agaain but be careful remember that no power should be attached to ROM.
    pls rate me
    thankyou
    Side A led volume indicator is low when duplicating tapes
    This is not a PrintWise burner problem. I posted incorretly. Henry
    2answers
    Accutower duplicator
    accutower won't burn cd it says "no clear cd'
    DUPLICATOR
    Hi there check the source drive by placing a cd in the draw close n draw wait 2 seconds open and see if the cd has rotated. If not then the drive is faulty. If so you may still have a faulty source drive check by placing audio cd in there if sound great if not Faulty.
    Thanks J
    3helpful
    Source drive not ready on 1 - 7 cd/dvd copier
    is it old? when a ROM have trouble in its lens that won't enable it to read any disc, then it will always tell you that drive is not ready.
    Top Zenith Televison & Video Experts
    Jaime Hernandez
    Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
