Washing Machines Logo
Spray nozzle won't quit spraying water even if door is open
Unimac commercial front load washer with spray nozzle kit in door
Posted by Ashley stakeman on
Barry Allen
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 18 Answers
Hey Ashley, thank you for the question. For me to answer your question, I need model number. But generally if dishwasher is not quit spraying water even the door is opened then the most likely cause is the door switch or the latches are not functioning correctly.
Please provide me with your model number so I will assist you more specifically.
Posted on Oct 01, 2022
Washer fluid on front
Sounds like one of your nozzles is clogged to me. Try this.....Get a spray can of air, like the computer air spray. Stick the long air can nozzle into the spray nozzle. Shoot some air back into the system and see if it frees your clog. When my fluid gets low, mine will get gunk in it and clog to the point of not spraying at all. Compressed air usually does the trick. If not, remove and clean or replace the nozzles.
Frigidaire stack washer and dryer water pump air bursts
follow this steps and use the common sense. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water
2answers
I bought a new 2600 psi pressure washer. It starts great. The pressure starts out fine. However, when I disengage the spray nozzle lever and then push it again there is along delay before I get any...
Hi. I think the problem may be called either vapor lock or cavitation, or it could be called something else, but the solution is to take the wand apart in the center and let the trapped water escape, then putting it back together before re-engaging the lever.
1helpful
I have a WD 1049C front load washing machine and behind the front seal there appears to be a mould buildup. How can we clean this area?
you would need to take out the whole drum assm....in other words you will need to dismantle the whole unit.....first thing first get lysol aerosol spray and spray around were there is mold.....i would take the unit outside and then spray it.....becuase once the mold have been disturbed it will find another place to live on......next u will need to use front load HE detergent......when you wash your laundry....start with the cold water clothes first then the last loads use hot water so it will wash clothes and disinfect at the same times...
lastly after all luandry have been washed ........open washer door over night so it can air out.......if not opening it at all the water and detergent that sits over night can cuase mold buildup and foul odors.....the gaskets are air tight and can not evaporate when door is closed.....
if your house has a/c i would put a fan in front of the washer over night..............
a feed back would be good if this helps anybody.....
my opinion........
the older top load washers are better..............
1helpful
2answers
Rear window washer does not spray fluid. When I push the rear window washer button, the front washer/wipers turn on. The rear wipers work normally.
I have the same problem with my 2000 chevy blazer as skornec had posted. I kinda already figured the hose or spray nozzle was plugged. But the problem with checking those items is that I don't know where the hose is located to the back wiper. And the only thing that could be I see that could be the spray nozzle doesn't even have holes that washer fluid could spray from. So basically I just would LOVE if someone could please inform this lame brain of where to find the spray nozzle on the rear window and where in the interior of my blazer does the washer hose run.
Water leaking through vent in door
Check your spray arm that nothing got stuck in its holes. make sure the spray arm is turning all the time when using the machine :
put the spray arm in 90 degree position, turn the unit on , open the door after few min check that the spray arm move...
make sure your seal of the door is clean and nothing prevent it to close evenly the door...
good luck 911servicetoday . com
1helpful
When I lock the doors on my 2002 Saturn SL1 the power door locks do not engage all they do is click but eventually stops but the doors will not lock or unlock using the power lock switch, How do I fix this...
Use WD-40 or similar penetrating spray & use the little red nozzle & get in behind & down sides as much as you can at door latch assy on doors. You may even find a slot right by the latch that you can stick nozzle in to spray all over. On front doors with key slots, push nozzle into key slot as far as you can & spray good while pulling nozzle out slow. Keep working them by hand at afirt until you feel them get a little easier, then start hitting power button up/down a few times & keep working it until they free up. If/when you've got them working again, spray same way, only with some "white lithium spray grease" to keep them lubricated after. I've had to resort to removing door panels to get at seized linkages in there before, but quite often, this will work. Keep me posted on results.
Whirlpool door lock error
turn off all water to your washer run the washer empty for a full cycle when the cycle ends the door will release
spray a lubricant such a WD40 into/onto the door lock
the door kit will not fix the problem
LG Steam Washer
please give me some more details like model number. that will be easy
Top Washing Machines Experts
Marvin
Marvin
john h
