Televison & Video Logo
Question about Samsung Televison & Video
I have Samsung UN65NU8500FXZA Which is not working.
TV power light blinks 2 times and tv tries to kick in but turn off again. I open the back cover of tv and disconnected the main board to power supply and noticed led lights were lid and tv screen was on but was dark (no picture) but when i connected the main board back to power supply the TV power light blinks 2 times and tries to turn on and then goes off again and same cycles repeats. I put small piece of tape and covered few wires of main board flex cable installed B/W power supply and flex cable and then i observed that the TV started sound was on screen was lid but there was no picture. Not sure if the main board is bad or there is any other issue.
Posted by AGHAB on
Hi My Samsung UN55F6300AFXZA WHO4 won't start but keep blinking red light 5 times and start blinking again with small interval.
1. open the back cover of the TV, disconnect the cable between the main board & the power supply.
2. Apply the AC power to the power module, if the back lights are not light up, change the LED strips (IF the back lights are bad, in some case, the power supply also been damaged), If the back lights are light up, please change the main board.
Samsung UN55F6300 won't start & keep blinking red light 5 times. New power supply board but didn't work. So, I replaced it back with original and worked fine for a few days & now won't start again.
1helpful
My HL-P5063W won't power on. I replaced the Digital Video Board and the lamp. When I power up the the TV, there are several clicks and never a picture. The lamp does not appear to getting any...
Did u ever replace the Ballast board for this tv?No?,that ur tv problems.The Ballast board only job are to ignite the tv projection lamp to make it work.U hearing multiple clicks,lamp never ignite up the Ballast board.
1helpful
2answers
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
19helpful
6answers
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
1helpful
2answers
Samsung TV turns off at random times
Samsung TV turns off at random times it is purely due to loose contact in 1 connector 2 print loose 3 compnent in power supply loose.
1helpful
5answers
Toshiba TP55H60 power down after start up
Try the following
1-unplug tv
2-remove bottom cover on tv
3-tap the power supply frame a few times (where the power cord enters the tv)
I had the blinking red light on my tv. I tried other solutions like removing the red wire a few times etc. Tapping the power supply frame solve the problem.
Marvin
Marvin
