Question about Samsung Audio Players & Recorders
Samsung FX30 Camcorder Mic input does not work!
I'm trying to input audio form my synth via the mini jack, but it doesn't work. The output is definitely there. Any advice anyone?
Posted by Edmund Gill on
1helpful
My canon xl1s is crackling all the time even with the mic plugged out. What can I do to fix this.
Chances are there is a lose connection to the audio jack. Do it do this when the camera is on a tripod or flat, sturdy surface with no movement? If you are adventurous enough you could find a repair manual online and attempt to open the area where the audio/mic inputs are and check the connectons there. if that's not the issue then it could be in the audio circuts and require professional repair.
You also might try an audio input through the audio line in or aux audio input and see if that stops it.
Can you get dual channel audio (four Chan) out of a toshiba l300 laptop?
Yes you can just grab a cable (both ends) male jack,like the male jack of the mic jack and plug one end to the PC and the other to your audio system
I am using pro tools 8 LE. I have a blue bluebird condenser microphone. the cable going into the mic is a male 3 pronged end. and the end going into my avid mbox mini is a normal ending (the ones that look...
The mbox mini is usb powered, wont work without power so your mac or pc must be powered on and connected. The blue led will be on when powered. Assuming you have the the appropriate cables, you want to make sure the condenser is plugged into the Mic/Line input. (Input 1 on the back of the mbox mini). All condenser mics require phantom power, so engage the +48V switch. Also make sure the DI (direct input) switch is not engaged. The input gain control is located on the front of the mbox... There needs to be speakers connected to the 1/4 output jacks on the back of the mbox or headphones on the front for sound output. Use the large knob for monitor volume control.
In protools: Create a Stereo Master fader track
Create a mono audio track
Set the input of the mono audio track to Mic/Line 1 Arm the track for record (click & make sure the R is red)
You should getting levels and sound output from your condenser.
How can I connect my Onkyo TX-SR507 to a PC to play MP3 files
The easiest way is to use a 1/8" stereo to dual RCA cord and connect the output of the sound card to an AUX input on the receiver. These cables are readily available and cheap. You shoul dhave 3 mini jacks on the back of the computer related to the sound card setup.
1) Audio input mic
2) Audio input line
3) Audio output line
Connect the receiver to the audio output line jack.
Dan
Adaptor needed for boom mic
Look in the manual for this information, contact Panasonic for the adapter
Input audio to PV-GS250 from an external mixer
Problem check list:
- Try another cable in the connection to rule out the cable
- Make sure the 1/8 plug goes in all the way
- Make sure you have it connected to proper outputs on the mixer (and that it's not a powered mixer!)
- Make sure you don't have the output volume up too loud on the mixer
Need of codes....
Hi I hope this will help http://www.dvcentral.org/tricks.html Tricks 4 XLR ins: Get the Canon MA-300 adapter and get yourself 4 XLR inputs. Perfect for a couple of wireless lavs, a boom, and another mic. Sure, it's less data for the audio channels, but it's plenty for voice recording. Sure, you can't digitize audio 3&4 easily, but it is possible, and it's just so darn useful to have four audio channels in the field. (Also, you can easily mount the wireless lav receivers right on the back of the camera.) Using the Canon on-camera mic via an XLR input: Say you're using a single boom mic, inputting via XLR 1. You've got XLR 2 doing nothing, and the on-camera mic doing nothing. Seems a waste. Well, all you need to do is adapt the on-camera mic to input through XLR 2. A short female-mini-to-male-XLR adapter will do for the audio signal, but the mic needs power. Simple, just get a short micro-mini extender cable, plug one end on to the mic, and the other into where the mic's connector would normally plug, on the camera's handle. Make sure the mic is switched to stereo, and voila, you have a second XLR mic. Monitoring in the field: Though many people told me it couldn't, the XL H1 downconverts to NTSC on the fly during recording, so you can plug a little monitor or deck into the video and audio out jacks and have yourself a video tap. Perfect for the director who wants to see what's going on through the camera. I used a little DV camera, and recorded it all so we could have a playback tape if needed. Very useful. (Note that the output NTSC is anamorphic, stretching the 16:9 image over the whole 4:3 frame. A monitor with a 16:9 switch is useful, or something that automatically adapts, such as what I used, a Sony PD-100 DVCAM camera.) Native slow motion: In a 24F project, shoot 30F and use Cinema Tools to slow down the footage to 24fps for a slight slow motion effect. Use 1/60 shutter speed for a standard look, or 1/30 for a slightly dreamier feel. Good Luck.
Canon XM2 -Audio Trouble
hi first: http://www.fixya.com/user-guide/p394384,m11809,gm57/Canon-GL2-Mini-DV-Digital-Camcorder.aspx yes you need to connect to the input jack: http://www.fixya.com/user-guide/p394384,m11809,gm75/Canon-GL2-Mini-DV-Digital-Camcorder.aspx if it wont work there is probeblya burned capacitor from the boosting good luck
Connecting analong camcorder to computer
The only Analog camcorder that has a USB Connection for transferring pictures or video is the SC-L770. The SC-L770 can transfer video (live or recorded) and still photos through the USB connection. You can also transfer audio using the audio cable provided. After installing the driver and software, you can begin transferring data using the software provided. Connecting to a PC 1. Connect a USB cable to the USB port on the PC. 2. Connect the other end of the USB cable into the proper terminal on the camcorder. (USB jack) 3. Connect the audio cable to the Line input jack of the PC. If the PC has no Line input jack, connect the audio cable to the MIC input jack. In this case, however, a noise may be produced depending on the PC. Notes: * If you disconnect the USB cable from the PC or the camcorder while transferring, the data transmission will stop and the data may be damaged. * If you connect the USB cable to a PC via a USB HUB or simultaneously connect the USB cable along with other USB devices, the camcorder may not work properly. * In this case, remove the other USB devices from the PC and reconnect the camcorder. Some other Analog Camcorders have a snapshot mode which allows you to take a still photo with your camcorder. However, you cannot transfer these to a computer unless you purchase additional hardware such as a capture card. Some capture cards have analog a/v inputs which will allow you to use the a/v outputs on the camcorder to connect to your pc and transfer images and video. You can purchase a capture card at most computer and electronics stores. Samsung does not support capture cards.
Open Questions:
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
