Radio Communications Logo
Question about Icom Radio Communications
ICOM IC-R6 is scanning very slow. 1 frequency in 2 second, not 100 frequencies in 1 second. Where is problem ? How to change speed of scanning in IC_R6 ?
Slow scanning in VFO and in memory mode. How to change scanning speed in IC-R6 ?
Posted by Bill on
  • Bill
    Bill Oct 09, 2022
    Programming via CS-R6 with Windows10 made problem. Scanning was very slow.
    The CS-R6 program through Windows 10 made problems with the scanning speed - it became very slow, one frequency in 2 seconds instead of 100 frequencies in one second.
    Through programming CS-R6 on Windows 7, the scanning speed returned to the corresponding one in the ICOM instructions - 100 frequencies per second
ADMIN Andrew
    Top Expert:
  • Icom Master
  • 53,112 Answers
The Fix
Programming via CS-R6 with Windows 10 made the problem. Scanning was very slow.
Posted on Oct 09, 2022
2answers
I bought a new logic unit (front face) of Icom F121 and it needs to be restored. How do you restore a logic unit for the Icom F121?
1- You have to to "Reserve" mode.2- Change Set Mode Access: Inhibit to Enable3- Common>>Secutity Change Set Mode Access : Inhibit to Enable4- Enter RX TX frequency and write to the radio.
or you can download version Rev 1.7 from here:
http://www.two-way-radio-tools.com/icom-softwares.html
http://www.two-way-radio-tools.com/icom-radio.html
Combine
You can follow the link below for a complete listing of FRS/GMRS frequencies.
http://www.walkie-talkie-watch.com/frs-gmrs-frequency.html
Bill B
How to add frequencies/channels to ICOM IC-F21 two-way radios?
Sorry, but your radio is limited to 16 channels in the 400-430 and 440-470 MHz ranges. The number of channels cannot be expanded, nor can the frequency coverage.
Bill B
4helpful
How to program a bc855xlt uniden bearcat scanning radio
Major Functions of Uniden BC 855 XLT Desktop Scanner
RANGES AND MODES:
29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM; 118-136 MHz AM
MEMORIES & MEMORY SCANNING:
• The 855 receives mainly via frequencies programmed into its 50 memory channels. It does not have a VFO or dial mode as such, but can scan within two frequencies.
• To scan memory channels, press SCAN. To hold a channel, press MANUAL.
• The 50 channels are divided into 5 banks (Bank 1: Channels 1-10, Bank 2: 11-20, etc.).
• Any of the 5 banks can be turned off from scanning. To turn a bank on/off, press its number while in Scan Mode. Active banks are illuminated in the display.
• SPEED toggles between 8 & 16 channels per second in both scan & search modes.
TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
• Press MANUAL.
• Press the channel number you wish to program using keypad.
• Press MANUAL again.
• Enter the desired frequency using the keypad.
• Press E (ENTER). (If you make an ERROR, press CLEAR & re-enter frequency.)
• To set 2-second delay, press DELAY. Confirmed by “DLY” in display. Same deselects.
• To lock out channel from scan, select it & press LOCK OUT. Same deselects.
PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
TO SELECT CHANNELS MANUALLY:
• Press MANUAL.
• Press desired channel number on keypad.
• Press MANUAL. Press MANUAL repeatedly to step through channels sequentially.
TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually, then press ? or ?.
TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
• Press MANUAL.
• Enter the lower frequency limit.
• Press LIMIT.
• Enter the upper frequency limit.
• Press LIMIT.
• Press SEARCH.
I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
http://uniden.com/pdf/BC860XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
www.RadioReference.com
BillB
2answers
I need the IC-F11/S to talk to my CP100 (vhf) model
Programming the CP100:
http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
Programming the IC-F11:
I believe one must purchase software and a programming cable to program the frequencies of this radio.
10helpful
3answers
Wanted manual realistic 2010scanner
The realistic 2000 series scanners do not have a "VFO" (variable frequency occilator) in the true meaning of the sence. This basicly means that they can only scan the channels or memories that you have programmed.
You can however set a low frequency (like 144 Mhz) and a high frequency (like 145 Mhz) and the scanner will "bounce" between the two, picking up anything in between.
Do you have the operating manual? If not, here is a copy
Turn on your Pro-2010 by rotating [VOLUME] clockwise. (When first turned on, your Pro-2010 may start scanning).
Rotate [SQUELCH] fully counterclockwise. You'll hear a rushing noise from the speaker. Slowly rotate [SQUELCH] clockwise until the noise just stops.
You're now ready to start entering frequencies.
Programming Frequencies
Before programming frequencies, make sure your Pro-2010 is turned on and the SQUELCH is adjusted.
Suppose you want to program Channel 1 to receive 162.55 MHz. Here's how you would do it:
1. Press [MANUAL] and select channel 1. You can do this in two ways:
press [MANUAL] continuously until the Display indicates Channel 1 or
by pressing [1] [MANUAL].
2. Press [PROGRAM] to enter the programming mode.
3. Enter the desired frequency. In this case, press the [1] [6] [2] [.]
[5] [5] keys. Check the display to make sure the frequency it shows
is the one you meant to program. If it is, press the [ENTER] key.
4. To add more frequencies, just press [PROGRAM] to advance to the next
channel and follow the steps above.
5. If you ever want to change the frequency entered for a specific
channel, just enter the new frequency "over" the old frequency using
steps 1, 2, and 3.
Make a mistake while entering the frequency? Just press [CLEAR], enter the correct frequency and press [ENTER]. If you're entering a new frequency in place of an old one, the old frequency won't be "erased" when you press [CLEAR]. It will remain stored on that channel until you correctly enter a
new frequency and press [ENTER].
You'll hear a "peep" sound as you press the various keys. This lets you know the key has been properly "entered" into your Pro-2010.
Using the Scanning Function
Your Pro-2010 will automatically scan all the channels you've programmed and stop whenever it finds a signal. To scan channels, just press the [SCAN] key.
To stop scanning, just press [MANUAL] and you can select specific channels
you want to listen to.
IMPORTANT! Your Pro-2010 won't scan unless SQUELCH is set to the point where no sound is heard if a signal isn't being received.
Delay Function
When your Pro-2010 is scanning, it will stop whenever it finds a signal on a channel. As soon as the signal ends, the scanning function will resume. Most communications heard will be two-way. To make sure you don't miss any replies, press [DELAY]. This will cause your Pro-2010 to stay on a channel for two seconds after the end of a transmission, giving you time to hear any reply. To release the Delay function, just press [DELAY] again. The Delay indicator will show on the display when the Delay function is used.
Lockout Function
You may want your Pro-2010 to "skip over" certain frequencies while it's scanning (such as continuously transmitted weather broadcasts). To "lock out" such channels, follow these steps:
1. Press [MANUAL] to stop scanning. Continue to press [MANUAL] to
advance to the channel you want to lock out.
2. When you reach the channel, press [LOCK OUT]. The display will show
[o] to indicate this channel will be skipped over during scanning.
3. To release the lockout, press [MANUAL] to stop scanning. Advance to
the channel that is locked out and press [LOCK OUT] once again. [o]
will disappear from the display.
If you use the lockout function on all channels, scanning will be impossible - you'll only be able to change channels using [MANUAL].
Speed Selection
Your Pro-2010 will normally scan channels at a rate of four channels per second. If you press [SPEED], channels will be scanned at a rate of nine per second. Press [SPEED] again to return to a rate of four channels per second.
Priority Function
You might want to scan other channels yet not miss a call on a channel of particular interest to you (police, fire, ambulance, etc.). The Priority function will let you scan other channels - but if a call is received on the Priority channel, your Pro-2010 will automatically switch to the
Priority channel!
1. Only Channel 1 can be used as Priority Channel: Key in the desired
Priority frequency into Channel 1.
2. Priority function works only when the unit is in Scan or Manual mode.
3. Press [PRIORITY] to start Priority function. A [P] will appear on the
display.
4. Press [MANUAL] or [SCAN] to listen to other channels. Your Pro-2020
will check the Priority channel and switch to it if a signal is
received on it.
5. To cancel Priority function, press [PRIORITY] again. the [P] will
SEARCHING WITH YOUR PRO-2010
One great feature of your Pro-2010 is its ability to "search" for frequencies being used. This means you can hear all the action on the airwaves in your area! To use this great feature, just follow these steps:
1. Press [PROGRAM] key.
2. Press [LIMIT] key. Enter the lower limit of frequency range to be
searched (such as 45.00 MHz). Press [ENTER].
3. Press [LIMIT] key again. Enter the upper limit of frequency range to
be searched (such as 46.00 MHz). Press [ENTER].
4. Press either [up arrow] or [down arrow] to start Search. [Down arrow]
will start search from the highest frequency and go down. [Up arrow]
will start from the lowest frequency and go up.
5. You can control the speed of the search by using the [SPEED] key to
accelerate or to slow down the search.
6. Search will stop when a frequency is found with a signal. To restart search, press [up arrow] or [down arrow]. In Program Mode, search range will be displayed each time [LIMIT] is pressed. It is impossible to change the lower frequency only: to change lower frequency you must change higher frequency first. The higher frequency can be changed any time.
Storing Frequencies
If you want to enter some of the frequencies found during search, do this:
1. Press [MONITOR] when your Pro-2010 finds a frequency you want to store.
2. Use [MANUAL] key to select a channel to enter the frequency your Pro-
2010 found. The display will show the frequency currently stored on
the channel, but don't worry - the old frequency will be erased when
you start to enter the new one.
3. Press [PROGRAM].
4. Press [MONITOR] again. The new frequency found during the search will
be displayed.
5. Press [ENTER] to put the new frequency into the channel in place of
the old frequency.
6. Press either [up arrow] or [down arrow] to resume the search. To
return to manual or program operation, press [MANUAL] or [PROGRAM].
To resume the search from one of the limit frequencies, press [LIMIT]
and then [up arrow] or [down arrow].
Error Indications
Sometimes when you try to enter a frequency for a channel or as a search range limit, you may find an ------ on the display. This means the frequency is in error and you won't be able to enter it into your Pro-2010. Such frequency errors usually mean you've entered a frequency outside the ranges your Pro-2010 operates on (such as 225.00 MHz) or you've put the decimal point in the wrong place (14.682 MHz instead of 146.82 MHz). Check carefully to find your mistake and then press [CLEAR]. You can now enter the correct frequency.
Hope this helps,
M3ODQ
9helpful
4answers
Getting started with the ICOM IC_R5
First set the squelch (gets rid of the hissing noise and allows the radio to scan)
to do this....
On the side are 2 buttons, the bottom one is monitor.
press and hold then look at the display,
turn the top dial until "AUTO" appears,
The squelch should now keep the radio quiet.
Now the tuning step..
You need to set this because if your radio was on 450.000 and you wanted to listen to 450.012.5 you would miss it if your radio was making 000.025 "steps". IE you would need 12.5 steps. This is the most common step used by ambulance etc in the UK, you will need to check local band plans.
Stick with 12.5 and you should get most stuff on VHF / UHF.
For airband 12.5 will get most stuff, but some is now changing to 8.33.
For HF (below) 136 Mhz I'd use 5
To set the step....
On the front there are 4 big buttons.
press [V/M.S.MW.SKIP] to select VFO mode,
then press [BAND.LOCK] to select the band you want to listen to,
then press [TS.SET] to enter the step
turn the dial to select your step (stick with 12.5 for now)
press [TS.SET] to exit back to VFO mode
To scan...
First set the scan type...
Press and hold the one that says [MODE.SCAN] for 2 seconds and look at the display,
turn the top dial until the screen reads ALL,
press [MODE.SCAN] again and the radio should start to scan with the 12.5 steps you set earlier.
If you want to change scan direction, just turn the top dial.
If you want to stop the scan, just press [MODE.SCAN].
When you hear something interesting, make a note of the frequency on the display.
To set memories (store frequencies).....
to get close to the frequency you made a note of, press [BAND.LOCK]
Then set the actual frequency with the top dial,
press and hold [V/M.S.MW.SKIP] for 2 seconds to select memory write mode (1 short and 1 long beep)
turn the top dial to select which channel you would like to overwrite. Start with 01.
press [V/M.S.MW.SKIP] for 2 seconds. ( 3 beeps )
Thats it!
Any more problems just post on here and either me or someone else will help.
M3ODQ
5helpful
2answers
Programming an Icom IC R5 scanner
This is a problem with any scanner which has no keypad..
to do this....
To set the step....
To scan...
Thats it!
M3ODQ
Icom r5
A quick "get you started" guide.....
to do this....
To set the step....
To scan...
Thats it!
M3ODQ
Top Icom Radio Communications Experts
Steve
Ngoro
Marvin
Marvin
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
