Washing Machines Logo
Question about Simpson Washing Machines
My Simpson EZYset 9.5kg Washer shows E17 and will not Spin. How can I fix it?
Washing Machine is in level Inlet taps are on and working but It will not spin . Shows E17
Posted by Milan Adamec on
My Simpson 750 Eziset toploader keeps showing error code E17 what does this mean and how do I fix it
E17 is
Machine goes out of balance or vibrates excessively when
spinning.
Make the machine level
Adjust feet to touch the floor
Redistribute clothes evenly.
My Simpson ezyset 6kg washer won't empty or spin after it w eat out of balance
check the lever to microswitch adjustment for the balance
normally it is also the lid open microswitch and if the unbalance was sever enough the lever will be on the wrong side of the switch
Changed lid lock on a 750 simpson ezyset washing machine.
most likely a problem program board not moving onto the next cycle and that is why the lid lock is still activated
2answers
I have simpson eziset 7.5kg has trouble spinning throws clothes to one side of tub
check that the machine is level
check that the wash bowl is level as a support mount may be failing and the bowl is not level
when it happens redistribute the clothes to a better balance point and re-spin
if it still happens ,seek the services of a washer technician.
How to fix error E17 code on eziset 9.5 kg top loader
Supply problem.
Check to see if water hose is plugged and test water pressure.Check water valve supply shut off.
See if filter is plugged.
Run full cycle w/no clothes in washer. Add 1 cup of vinegar,no soap.
2helpful
I just bought my washer today and it won't finish the first cycle. It is showing "E17" and won't drain. What does "E17" mean and how can i fix my washer. Help!!
When the washer shows error code E17 you need to turn the tap fully on and check that the supply hose is not bent or jammed up, next make sure the filter is clean. Then make sure the water pressure is not too low. After you do all that, run a load with no clothes in the washer and use one cup of white vinegar and the code will dissappear
Top Simpson Washing Machines Experts
Ngoro
Jerry Kramer
Jerry Kramer
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
