Question about HP Office Equipment & Supplies
Hp laserjet 3015 50.40 error - HP Office Equipment & Supplies
Roger R
  • HP Master
  • 1,603 Answers
Hi
Please unplug printer for 10 minutes and switch the power outlets used by the printer. Thank you.
Posted on Sep 30, 2022
4answers
How to fix scanner error 6?
herewith 3 suggestions (try searching the HP forum or search engine 'scanner error 6'). Read all of them before you decide to do anything and only then decide which order if any to do them depending on ease vs likely effectiveness.
HP LaserJet 3055 Scanner Error 6
HP Laserjet 3055 Scanner Error 6
6.July.2015
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
10helpful
2answers
HP Color LaserJet CP1515n Printer is showing error 51.23. please help
error 51.23 on the hp color laserjet cp1515n printer. please help
Hp laserjet m1522nf 10.0000 supply memory error
Are you using HP toner? Try reseating the cartridge. If it's still getting the error, replace the cartridge.
34helpful
3answers
Scanner error 6
Problem for HP LaserJet M1120 MFP All-In-One Printer Scanner error 6
6helpful
Error 51.23 on HP 3600 color laserjet printer
HP Laserjet 2820 getting error 10.1004 supply error when installing a new imaging drum. Anyone ever got this error msg? Thanks
Does it work with this error....if so you wanna
make sure that you have a HP cartridge, sometime the chipset is not recongnize....and you have some function that doesn't work. If you try all this, call HP.
Open Questions:
0answers
HP Designjet 1050 / 1055 CM green tint Problem: -------- HP Designjet 1055 CM Postscript: Black and gray-levels printed with green tint Description ----------- My HP Designjet 1055CM PS prints gray levels and black color with green tint. Somehow, the printer does not mix C-M-Y to get the proper color tones. Just to check if using the pure black ink tank as a reference, I tried to force the printer to use it by sending the following simple Postscript test-file to the printer. -------------------------------------------------------------- %!PS-Adobe-3.0 EPSF-3.0 > setpagedevice %%BoundingBox: 0 0 1500 200 newpath 100 70 moveto 0 100 rlineto 100 0 rlineto 0 -100 rlineto -100 0 rlineto closepath gsave /DeviceCMYK setcolorspace 0 0 0 1 setcmykcolor fill stroke showpage --------------------------------------------------------------- It should draw a 100% black rectangle. The test.ps was sent to the printer with the command 'lpr -l test.ps ' The -l should force the cups printing system to send test.ps in raw format i.e. without any preprocessing by the printing system. The processing should be done completely within the PostScript RIP of the printer. However, the print has the exact same green tint as if I print through any application. How can the printer be forced to use the black cartridge? Any idea how to get rid of the green tint? My Mac is running macOS Monterey 12.6 Apart from the green tint issue, the printer is working fine. Any help is greatly appreciated! Best regards!
Ben Johnson
Marvin
Marvin
